How to do a compression test if the motor is not in the car?
Old Feb 28, 2006 | 09:15 AM
92integraVTECgsr's Avatar
Default How to do a compression test if the motor is not in the car?
Old Feb 28, 2006 | 12:48 PM
gotboostedvr6's Avatar
Default Re: How to do a compression test if the motor is not in the car? (92integraVTECgsr)
stick screw driver in tb to keep it open
and with the flywheel installed and the trans mounted to the motor, the trans grounded and power to the starter post, jump the starter solinoid
Old Feb 28, 2006 | 01:00 PM
Default Re: How to do a compression test if the motor is not in the car? (gotboostedvr6)
there is no transmission either.. it is just the long block with the flywheel attached?
Old Feb 28, 2006 | 01:19 PM
you can do a leakdown thats all
Old Feb 28, 2006 | 01:32 PM
that's what i thought. thanks.
B16Drag
Apr 27, 2005 11:11 AM
JDMEMM
Oct 21, 2002 10:56 PM
S13 slide
Feb 6, 2002 05:50 PM
