What would be the compression if I put the h22 type S pistons on my h22?
Old Feb 27, 2006 | 05:01 PM
jdm knight's Avatar
Default What would be the compression if I put the h22 type S pistons on my h22?
I have civic hb with an h22 and I'm not sure if I should get the type S pistons or get aftermarket pistons for a All Motor application.
Old Feb 27, 2006 | 05:11 PM
BergRacing21's Avatar
Default Re: What would be the compression if I put the h22 type S pistons on my h22? (jdm knight)
to answer your topic question the type-s pistons have a 11.1:1 compression ratio. how big to plan to build? cause they are a good set of pistons to start out with but if your goin full out drag...and know your upgrading everything and running a large shot of n2o maybe look at gettin a higher compression.
Old Feb 27, 2006 | 05:18 PM
jdm knight's Avatar
Default Re: What would be the compression if I put the h22 type S pistons on my h22? (BergRacing21)
Well here is my set up,
Crower stage 3 cams.
Skunk2 valve springs and retainers.
Skunk2 cam gears.
Skunk2 intake manifold.
ARP head studs.
Eagle rods.
The thing is if I should go with the type S pistons or aftermarket pistons.
Old Feb 27, 2006 | 05:20 PM
mgags7's Avatar
i cant believe you actually asked that....the type s motor is 11:1, its an h22....an h22 + type s pistons = ??
Old Feb 27, 2006 | 09:38 PM
hu's Avatar
hu
With Crower Stage 3, you should have higher compression than 11:1
Old Feb 27, 2006 | 10:08 PM
JTCdudeman's Avatar
Master H Technician
Default Re: What would be the compression if I put the h22 type S pistons on my h22? (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">With Crower Stage 3, you should have higher compression than 11:1</TD></TR></TABLE>
Old Feb 28, 2006 | 08:32 AM
Fly1865's Avatar
Default Re: What would be the compression if I put the h22 type S pistons on my h22? (JTCdudeman)
https://honda-tech.com/zerothread?id=1542257
Old Feb 28, 2006 | 08:54 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTCdudeman &raquo;</TD></TR><TR><TD CLASS="quote"> ??</TD></TR></TABLE>
hes trying to say that those cams do better with more compression than 11:1
Old Feb 28, 2006 | 09:06 AM
JTCdudeman's Avatar
Master H Technician
Default Re: What would be the compression if I put the h22 type S pistons on my h22? (mgags7)
oh... I hope that was the idea... Honestly, I just thought it was another attempted spreading of misinformation...
Pippen_001
16
Jul 28, 2006 07:48 PM
tgh22a
11
Feb 12, 2005 09:54 PM
SilverEk3dr
Nov 19, 2003 02:32 AM
lazy bum shaughn
May 3, 2003 11:31 PM
