camshafts(need help)
Old Mar 29, 2002 | 10:07 AM
speeddave's Avatar
Default camshafts(need help)
i searched but nothing so i'm gonna brave a post, j/k. anyway i am looking for the advertised duration of these cams;
-itr/ctr cams
-skunk2 stage 2
-jun 3
i am thinking of selling my zex kit and buying some cams instead, i am really interested in the comp cams(i get a good deal) the adv duration of the cam i am looking at is; intake 292/exhaust 296, the cams are gonna be going in a ls/vtec with pr3 pistons(11.2:1) will i also need adj. cam gears and dyno time right away?
thanks guys.
_______
Old Mar 29, 2002 | 10:53 AM
TypeR0207's Avatar
Default Re: camshafts(need help) (speeddave)
Searching for you .......
STOCK GSR profile (both b17a and b18c1)
INTAKE lift - 10.6 mm,duration - 230 @1mm valve lift
EXHAUST lift - 9.4mm, duration - 227@1mm valve lift
STOCK CTR and 2000-2001 ITR profile
INTAKE lift - 11.5 mm,duration - 243 @1mm
EXHAUST lift - 10.5mm, duration - 235 @1mm
Toda A's
INTAKE lift - 11.6 mm,duration - 250 @1mm
EXHAUST lift - 11.2mm, duration - 240 @1mm
Skunk2 Stage I
INTAKE lift- 11.58 mm, duration 252 @ 1mm
EXHAUST lift - 10.9 mm, duration 249 @1mm
Old Mar 29, 2002 | 10:55 AM
TypeR0207's Avatar
Default Re: camshafts(need help) (TypeR0207)
Jun Type 2
INTAKE lift - 12.0 mm, duration 266.6 @ 1mm
EXHAUST lift - 10.9 mm, duration - 265.3 @ 1mm
Old Mar 29, 2002 | 10:56 AM
TypeR0207's Avatar
These are all at 1mm, not the advertised duration, so are a more realistic approach to cams.
Check out the R forum as well. Some of the biggest gear heads in the tuning business hang there.
Old Mar 29, 2002 | 01:24 PM
speeddave's Avatar
thanks man, good info, does duration @ 0.050" compare to 1mm? sorry i'm an old domestic fan, and i can't think right now. also any info on comp cams? good or bad?
edit: actually i looked, so the comp cams i am looking at are comparable to the skunk2 stage 1's, based on duration @ 0.050, there both aprox 250lift. i was under the impression that those cams were fairly tame?
[Modified by speeddave, 10:28 PM 3/29/2002]
bottlefedb18c1
Jun 9, 2003 06:56 PM
12345
Feb 11, 2003 10:42 PM
b18cInside
Dec 22, 2002 05:13 PM
speeddave
Mar 29, 2002 11:03 PM
