What components are you running in the front? (Size Question)
Old Feb 27, 2006 | 09:39 AM
Chunty Butt Kevin's Avatar
Default What components are you running in the front? (Size Question)
So I purchased a car and the previous owner put some 6.5 Alpine coaxials in the back, they didnt fit. It's about 4-5 inches long and tried installing them in the fronts for a test fit, turns out they were too big and will touch the glass of the window if I jammed them in there.
I really wanted to run some Type R's. What component speakers are you guys running? I wanted a 1 piece speaker, no seperate tweeters. Is there an adaptor I can use to fulsh out the speakers?
I'm planning to get some speakers for the back also.
Old Feb 27, 2006 | 09:44 AM
incubus's Avatar
Default Re: What components are you running in the front? (Chunty Butt Kevin)
what car? u usually have to use speaker spacers that move the speakers further out in hondas.
Old Feb 27, 2006 | 09:52 AM
96 ek
Old Feb 27, 2006 | 10:42 AM
shyboy817's Avatar
You would have to use speaker spacers, normally made out of mdf wood or something, or you can cu tthe stock speaker bracket in the back to get more room, it'll give you a few more inches.
Old Feb 27, 2006 | 12:24 PM
ill probably be picking these up, kinda expensive but i can run any size speakers on them
Old Feb 27, 2006 | 01:54 PM
Znypar's Avatar
Default Re: (Chunty Butt Kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboy817 &raquo;</TD></TR><TR><TD CLASS="quote">You would have to use speaker spacers, normally made out of mdf wood or something, or you can cu tthe stock speaker bracket in the back to get more room, it'll give you a few more inches.</TD></TR></TABLE>
overrated
imo
the mounts aren't that great from what ive seen
Old Feb 27, 2006 | 01:59 PM
shyboy817's Avatar
Default Re: (Znypar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Znypar &raquo;</TD></TR><TR><TD CLASS="quote">overrated
imo
the mounts aren't that great from what ive seen</TD></TR></TABLE>
I wasn't giving the best suggestion, just giving him an optional idea.
Old Feb 27, 2006 | 05:11 PM
suspendedHatch's Avatar
Default Re: (shyboy817)
Those Q forms are cool, I plan on getting some, but from what I've seen, they dont have mounts. They just sit there. That sucks and it's kind of dangerous.
Old Feb 27, 2006 | 07:06 PM
EBP_SI's Avatar
Default Re: (suspendedHatch)
i would just make some custom ones with glass because then you can play around with the angles of the mid's/ tweets
Old Feb 27, 2006 | 07:36 PM
it looks like it replaces he dead pedal. if so, theres no room ill call them about this
Old Feb 27, 2006 | 08:02 PM
foz's Avatar
foz
Alpine Type R coax's and components both come with Honda spacers. Find a local Alpine shop see if they'll kick you one, should be free if it's just lying around, maybe 5 bucks...
Old Feb 28, 2006 | 11:42 AM
8520's Avatar
Default Re: What components are you running in the front? (foz)
Type R's sound like poo.
I run boston components, but if you're for a great sounding component set, I would recommend finding a local diamond audio dealer and listening to some D661s's for the exact same price as the r's.
You can make anything fit with time
Old Mar 1, 2006 | 06:11 AM
called crutchfield. recommended me some polk momos for like 299 way out of my budget.
boston acoustics 2 ways might fit
Old Mar 1, 2006 | 10:22 AM
8520's Avatar
How is it that 300 for polks is too much but 400 for type r separates isnt?
Old Mar 1, 2006 | 12:58 PM
foz's Avatar
foz
Default Re: (got_no_sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by got_no_sol &raquo;</TD></TR><TR><TD CLASS="quote">How is it that 300 for polks is too much but 400 for type r separates isnt?
You need to check your prices you shouldn't be paying more than 250 for a new set of alpine R seperates, or 150 for alpine R coax's
Hell I bet that's what Crutchfield sell em for
Old Mar 1, 2006 | 01:01 PM
foz's Avatar
foz
Default Re: (foz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chunty Butt Kevin &raquo;</TD></TR><TR><TD CLASS="quote">I really wanted to run some Type R's. What component speakers are you guys running? I wanted a 1 piece speaker, no seperate tweeters. Is there an adaptor I can use to fulsh out the speakers?
I'm planning to get some speakers for the back also.</TD></TR></TABLE>
Edit... It's a good coax for the money 150 from the Crutch and it will come with adaptors you can use.
Old Mar 1, 2006 | 02:47 PM
Tornadom's Avatar
I have Rainbow contour series. The magnet is on the same side as the speaker cone, making them very shallow. The sound is very good as well.
Old Mar 1, 2006 | 03:07 PM
8520's Avatar
Default Re: (foz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foz &raquo;</TD></TR><TR><TD CLASS="quote">You need to check your prices you shouldn't be paying more than 250 for a new set of alpine R seperates, or 150 for alpine R coax's
Hell I bet that's what Crutchfield sell em for</TD></TR></TABLE>
Yep, got my prices wrong. Too many to remember.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">I have Rainbow contour series. The magnet is on the same side as the speaker cone, making them very shallow. The sound is very good as well.</TD></TR></TABLE>
Mmmmmmmmm rainbow
Old Mar 1, 2006 | 03:34 PM
Tornadom's Avatar
Mmmmmmmmm rainbow </TD></TR></TABLE>
Yeah, Rainbow makes a good product. A buddy of mine has a higher end Rainbow component set. His is a 3 way Mid Bass/Mid/Tweet. His setup is very sweet, in the front doors, fiberglass pods.
Modified by Tornadom at 9:19 PM 3/3/2006
Old Mar 3, 2006 | 08:21 PM
Tornadom's Avatar
Default Re: (Tornadom)
Basically, with enough time, creativity and money anything can be mounted anywhere. I think 6.5's will fit in the front doors with minimal work.
Old Mar 9, 2006 | 10:52 AM
LSzar's Avatar
i picked up the kick panels you still have to mount them with hardware provided and cut for the speakers. i think you might have to custimize it to fit 6.5 speakers. im putting in the polk mmc 5250 that i got of ebay for around 150 new
Old Mar 9, 2006 | 08:43 PM
Tornadom's Avatar
Default Re: (LSzar)
Nice setup. Good luck.
HondaBryan43
Audio / Security / Video
10
Mar 8, 2009 11:23 AM
SIRIUS VTEC
Mar 28, 2008 03:28 PM
Paul*DC4
Mar 19, 2008 07:44 PM
eL
Honda Fit
Apr 14, 2007 02:32 AM
STC
Jul 1, 2002 05:04 PM
