Speaker Size
Old Dec 29, 2008 | 11:55 AM
HondaBryan43's Avatar
Default Speaker Size
I was just wondering what is the speaker size in an 89 Civic Hatchback? I only have 2 speakers and they are the door speakers. Im just trying to replace them with something that fits right back in the stock location. thank You.
Old Dec 29, 2008 | 11:59 AM
rallypoint_1's Avatar
Default Re: Speaker Size
6.5" in the doors. Get shallow mount speakers or you might have problems rolling your window down.
Old Dec 29, 2008 | 06:24 PM
schock3's Avatar
the man is 100% right
Old Dec 29, 2008 | 07:41 PM
acmoc's Avatar
wow really, in the crx I think they're around 5 inches, is that rite?
Old Dec 29, 2008 | 08:29 PM
SIred91's Avatar
Rainman
No. In my 91si all 4 speakers are 6.5
Old Dec 29, 2008 | 08:36 PM
KRock459's Avatar
Many audio "fit guides" call for a 5.25" but a 6.5 is the ticket, 2.5" of depth max. You may need to cut the back of the speaker bracket/rain baffle, easy task.
Kirk R
Old Dec 29, 2008 | 08:37 PM
njn63's Avatar
Stock they were 5.25" in the front. You can cut the back out of the plastic mount though and fit 6.5" speakers in there easily.
I'd stick with shallow mounts if available though to avoid problems with the windows as mentioned above.
Old Dec 29, 2008 | 10:01 PM
acmoc's Avatar
oh, You're rite, just looked it up.
You think 6x8 fit in the back?
Old Mar 7, 2009 | 02:51 PM
92gvr4civic91's Avatar
New User
I have JL audio's (TR650-CXi) at 2.44 mounting depth and they are 6.5", I cut the bracket out on the passenger side so speaker would fit through but it doesnt because the speaker still wont sit flush with the bracket. What size bracket should I buy so these speakers can work (depth and width). I won them at a local car show and dont want to have to buy some if these work.
Old Mar 7, 2009 | 06:55 PM
New User
bump as I didnt feel it was necessary to start a new thread to a similar discussion.
Old Mar 8, 2009 | 11:23 AM
fcm's Avatar
fcm
Old Fart
88-91 Civic hatch used standard 6.5" speakers, not to be confused with oversized 6.5" speakers] in front and back, but could come with 5.25" in the rear, [even in the front] speaker housing will hold either a 5.25" or standard 6.5" speaker, [screw mounting holes for both are in the stock plastic speaker housings] as mentioned the mounting depth is 2.5" max without mods, with mods up to a 3" deep speaker will fit, mounting diameter, [hole size] is 5".
92gvr4civic91 your JL Audio TR650CXi are oversized 6.5" speakers they need a 5.56" diameter mounting hole.
Your best option is to replace the stock plastic speaker housings with custom MDF housings. 94
1sloEM1
Audio / Security / Video
Feb 18, 2010 04:53 PM
93civicexthug
Apr 29, 2007 06:22 AM
Bone Stock
Feb 3, 2006 07:43 AM
youngwon22
Sep 10, 2003 06:33 PM
FrostyGSR
Dec 19, 2001 03:42 PM
