Advance engine, how many degrees max ?
what would be the effects of running more? when I bought my car, previous owner had the thing set at about 20. would the knock sensor on the car save the engine from potential damage or should I be worried? I didn't hear any knocking before I reset it to 18.
My best dyno # from stock cams came at 20 degrees, and with my B's the best # came at 16 degrees.
[Modified by kkim, 10:47 PM 3/29/2002]
My 2001 I can't advance the timing at all. Isn't that an ecu thing?
okay, but is it safe to run at 20, stock, other than maybe the knock detector kicking in and retarding the timing?
Here's the difference between seventeen degrees and twenty three degrees:
Huge, huh?
I run/ran 19 degrees on the streets . . . No AC or PS loading the engine though.
Huge, huh?
