shift linkage pin replacement
i have a 89 crx hf with b-series swap and im putting a hasport shift linkage on today.
however, the pin that holds the "swiveling"(sp) part to that actual trans is kinda flattend out so i plan on drilling it out. when i do this to replace it could i just put like an equal sized bolt through to hold it together? if not what else would work to hold it in place so i dont have to worry about it?
thanks in advanced,
jake
thanks in advanced,
jake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1RMDave »</TD></TR><TR><TD CLASS="quote">i use a bit i made for my air hammer, zips it right out.</TD></TR></TABLE>
Do you have a picture of that? I would like to see it and maybe make one for my air hammer.
I lost the pin to my shift linkage one time, and I went to Ace Hardware and they had a similar part. I'm pretty sure it's just a tension pin? Something like that, but it was just a pin w/slot, it was the exact same size, but a too long. Nothing a hacksaw/Dremel can't fix.
GsrTurboCRX88
24
May 30, 2006 07:14 PM
