88 crx auto to manual
Old Feb 26, 2006 | 06:51 PM
nudvl's Avatar
Default 88 crx auto to manual
Before u search try search! I have! every possible way to search it i have tried!
Everything I have read says there is a hole on the fire wall for the clutch cable to go through when you do the swap. right?! well my car doesn't. so do I drill a hole or WHAT????? any ideas?
Old Feb 26, 2006 | 07:23 PM
silentdork818's Avatar
Default Re: 88 crx auto to manual (nudvl)
Youre probably going to have to drill a hole. Some cars had them and some didnt.
Old Feb 26, 2006 | 07:26 PM
Mugencrxsir1's Avatar
Default Re: 88 crx auto to manual (silentdork818)
There's a lot more involved than drilling a hole, you have to widen the shifter hole to accept the stifter and linkage movement. And a bunch of other stuff that I'd rather not get into. Goodluck and let us know how it goes.
Old Feb 26, 2006 | 07:30 PM
Default Re: 88 crx auto to manual (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">There's a lot more involved than drilling a hole, you have to widen the shifter hole to accept the stifter and linkage movement. And a bunch of other stuff that I'd rather not get into. Goodluck and let us know how it goes. </TD></TR></TABLE>
No you dont!!! I just did an 89 CRX auto to manual a month ago. Other than the hole it was a 100% bolt on conversion.
Old Feb 27, 2006 | 04:56 PM
nudvl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdork818 &raquo;</TD></TR><TR><TD CLASS="quote">No you dont!!! I just did an 89 CRX auto to manual a month ago. Other than the hole it was a 100% bolt on conversion.</TD></TR></TABLE>
so tell me more!!!! how big did u drill the hole where did u drill the hole???? pics alil insight anything.
Old Feb 28, 2006 | 12:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nudvl &raquo;</TD></TR><TR><TD CLASS="quote">
so tell me more!!!! how big did u drill the hole where did u drill the hole???? pics alil insight anything.</TD></TR></TABLE>
It helps if you have a 5-speed EF for comparison. The hole itself should be just big enough for the cable to fit through, but not so big that it fits sloppy. You have to drill two more holes for the shift linkage but other than that it all bolts up. Good luck with the rear mount.
Dyce
13
Aug 21, 2007 03:49 AM
boosted97civic
Jan 10, 2007 09:40 AM
tuner6r
15
Mar 20, 2005 09:45 PM
consolidatedbord
Jan 28, 2005 02:08 PM
