WTT/FS Garret 60 trim,LS block,Dizzy,82mm HG,Drag,steelies,VC,misc...
Things for sale or trade...
T3/T4 Garret 60 with a 56intake 60 exhaust it was welded to the exhaust so it will have about a 3inch piece you can weld your exhaust straight to and eliminate having to buy a downpipe. I had straight 3inch coming off of it straight out.. It has a small oil leak it drips very slowly. I'm gonna take it off the car tommorow and inspect it throughly.. It runs fine but makes a weird noise if you rev it up under idle and let off it works still though but should be rebuilt has some shaft play.. I got qouted at 275 for a rebuild this turbo will make huge power.. The car ran a 13.2 in a eg hatch with street tires and only 8psi..lOOKING FOR 100 shipped..
B-series drag manifold 150 firm...
OBD-1 LS block was in running shape but has been sitting about 1 year. It has alittle surface rust but would be fine with a hone or bore and rebuilt. 100 firm
OBD-1 LS Dizzy 75 bucks FIRM
B-Series- UNORTHODOX Lightweight crank pulley its polished 50 bucks shipped
LS 82mm brand new MR.Gasket headgasket 60 bucks firm
Also have a MSD boost retard **** and harnesses make offers.
96 LS valvecover has the 2 breather holes of the newer style perfect for powdercoating 40 bucks..
i HAVE EXTRA B-SERIES TEGGY Alternator,Intake manifold,throttle body make offers..
14inch steelies with mint tires 50 bucks
I also have some old school i believe EF wheels look pretty decent with M&H 20x8x14 slicks still got all the wear marks fresh, this size tire is famous for not holding air so you gotta pump them up at the track and let the air pressure down in the staging lane if left sitting they deflate to 6psi after about 1hr and stay thier..make offers
Things I need LS aftermarket Intake manifold and throttle body,oil pressure,water temp,air fuel guages,EG hatch midwing,EG hatch rear black interior, just make offers...
I'M IN FREDERICKSBURG VA...
Can get you pics if need be just leave your email..
I also have 2 p75 ECU's 50 bucks each..
I also have a EG hatch OEM Carbon fiber hood it does have a crack but can be fiberglassed and painted or you can do like i did with my last 1 and just lay down a sticker paint it then pull the sticker off and still have the CF look.75 bucks will be off of the car hopefully this weekend waiting for new hood to come in..
Pics of turbo to: bayton1@umbc.edu
how much for the 14inch steelies shipped to 54914? Email me pics of the tire tread too. KENetics1@new.rr.com
EK FLY
Mid-Atlantic (Sales)
Dec 21, 2007 03:42 AM
Samuels
Mar 3, 2006 03:23 PM
Samuels
Feb 26, 2006 10:47 AM
Samuels
Jan 24, 2006 01:27 AM
