Honda S2000 Honda S2000
possible to hit 12.99 N/A???
Old Feb 26, 2006 | 02:13 PM
pushinlsteg's Avatar
Default possible to hit 12.99 N/A???
I have an 03 Ap1, I'm gonna go with intake header exhaust, 4.77's, hondata IMG, vafc tuned and drag radials to start with...
this is my daily driver, my track car is a turbo integra I'm rebuilding a motor for.
I've gotten the integra into low low 13's with stock tires, 185 wide with 2.0 60ft times with the basic turbo setup, open diff, no LSD. (building a new motor now).
I'm a pretty decent driver, I can launch FWD or RWD with minor flaws...my question is has this already been done? do you think its possible? I'm at about 300 FT elevation, not too bad.
I wasn't gonna mess with this thing and leave it stock but looks like I'm gonna.
The fastest STOCK ap1 I've seen was 13.6 or 13.7 and that was to me.
I've heard of 13.2's with 4.77's but I mean you can never tell if people are bullshitting a few 10th's which matters.
I heard 4.57's were mid 13's and 4.77's can do low 13's but I'd like to hear some of your opinions.
its not that important to me just a goal, which I'm thinking is possible with the right conditions and launch.
Well let me know what you think, thanks.
Old Feb 26, 2006 | 02:15 PM
papa5murf's Avatar
Default Re: possible to hit 12.99 N/A??? (pushinlsteg)
drop the vafc II and get an aem ems.. and you should be able to hit that number
Old Feb 26, 2006 | 02:31 PM
Default Re: possible to hit 12.99 N/A??? (papa5murf)
damn man, we're talking $300 to $1300, EMS for a non-turbo daily driver, you're killing me...lol how about just low 13's??
Old Feb 26, 2006 | 02:48 PM
papa5murf's Avatar
you could do it with the right combination of I/H/E
Old Feb 26, 2006 | 03:35 PM
llllAP1llll's Avatar
Here is what I can tell ...how much money do you really have to spend on the S2k. The best route to go and its really really easy. Dont buy a exhaust for this car...biggest waste of money ...all you need is the new design J's Header and test pipe. Get a V2 with a spoon throttle body and a VAFC with some Ricks 4.57's and a comptech diff. Finally lose everything in your trunk that night and you will run high 12's all day if you can drive. No need for drag radials...just goodyear eagle f1's ) Same setup I had except I had a hardtop and dished the overated softop on the car and shedded about 150 lbs off the car. Hope this helps! Oh yeah im a noob so you dont have to listen to me if you dont want to ...what do I know right?
Old Feb 26, 2006 | 04:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">you could do it with the right combination of I/H/E</TD></TR></TABLE>
Do you have 4.77's? where did you get them and did you upgrade to the comptech housing?
Old Feb 26, 2006 | 04:12 PM
SimbaDogg's Avatar
Default Re: possible to hit 12.99 N/A??? (llllAP1llll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llllAP1llll &raquo;</TD></TR><TR><TD CLASS="quote">Here is what I can tell ...how much money do you really have to spend on the S2k. The best route to go and its really really easy. Dont buy a exhaust for this car...biggest waste of money ...all you need is the new design J's Header and test pipe. Get a V2 with a spoon throttle body and a VAFC with some Ricks 4.57's and a comptech diff. Finally lose everything in your trunk that night and you will run high 12's all day if you can drive. No need for drag radials...just goodyear eagle f1's ) Same setup I had except I had a hardtop and dished the overated softop on the car and shedded about 150 lbs off the car. Hope this helps! Oh yeah im a noob so you dont have to listen to me if you dont want to ...what do I know right? </TD></TR></TABLE>
exactly...don't listen to this guy. an exhaust such as the t1r or the j's 70 w/ the test pipes are proven to net at least 8 hp to the wheels. ontop of this, if you're looking at these two exhausts (both single exits) you're going ot drop about 45 lbs in weight. weight loss, and power gain...a two fold attack at your 12.9 goal.
and for all the people who are saying hondata...there is no hondata. VAFC, EMS (my choice), or i believe emanage is another alternative. if you have an ap1, going to ap2 sized rubber in the rear, along w/ a much lighter wheel (rpf1, rm+s, rg, rg II, te37 etc) will definetly help get you there.
Old Feb 26, 2006 | 04:18 PM
papa5murf's Avatar
Default Re: possible to hit 12.99 N/A??? (SimbaDogg)
^ can also use the hks fcon for tuning.. .but good luck finding someone that knows how to use it to tune..
Old Feb 26, 2006 | 04:19 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pushinlsteg &raquo;</TD></TR><TR><TD CLASS="quote">
Do you have 4.77's? where did you get them and did you upgrade to the comptech housing?</TD></TR></TABLE>
i don't have them... (i'm going boost)... but i have driven a car with them...
there should be a group buy on s2ki.com
comptech rear diff would be wise since you seem to want to drag race the car..
Old Feb 26, 2006 | 06:00 PM
thanks to all for your input, if theres any more info, keep it coming, thanks.
Old Feb 26, 2006 | 07:19 PM
Nishant's Avatar
if I can run a 13.3 with only 4.77 and an intake, you can def run 12.9 with IHE, 4.77 and drag radials. I am pretty sure that if I worked on it, I could hit 12's with drag radials as is now. i don't have the time, money, or interest to do it though
pwrofdrm's Avatar
I believe it's very possible, user "Nishant" ran a 13.3 on stock rubber with just the 4.77's and an AEM V2.
Look up Jack from P1's recent thread, he netted 6hp to the wheels using an AEM V2 and raising the VTEC cross over point a couple hundred RPM's using a VAFC.
If I keep my car I'm going the same route as you, 12's N/A.
I had the 4.77's from the s2ki group buy, a VAFC-II, K&N Drop In Filter, Hondata Intake Gasket, Berk Testpipe, and a Spoon catback exhaust. I think that combined with the removal of the spare tire and tools, and possibly even the passenger seat, 12's are possible. I pussied out however and never installed any of it except the exhaust
I'm going to get flamed for this, but expletive the Comptech Differential! Spend your money elsewhere!
Old Feb 27, 2006 | 04:04 AM
SimbaDogg...you still wouldnt know how to drive your car if Alex Reiger taught you everything about driving. Lets say your theory on the j's exhaust is correct...because yours is...it does net around 7-8hp...but does it net out 11.4 hp without an exhaust and saving about another 12lbs off the car without the exhaust...so yeah dont listen to me I dont know what im talking about. See everyone of you that say you can drive your car into the 12's....thats awesome but how long is your diff going to last you broke back mountain fagots!!! Learn a lil from someone who knows some **** and who actually has had there car longer than you have probably had your license. Thats why all you noobs stay here instead of S2ki.
Old Feb 27, 2006 | 07:58 PM
Francesco's Avatar
13.7 in stock form is possible...
get the right I/H/E and gears + some tuning and i think 12.99 is achievable.
Old Feb 27, 2006 | 11:09 PM
Ponis's Avatar
Noob to gears... period... but doesnt that effect highway driving..????
Old Feb 28, 2006 | 04:07 AM
SimbaDogg's Avatar
Mmm...i stay here instead of s2ki? funny how my membership is rolling on 2 years in 18 days on s2ki . how old are you man, seriously? 17...18? are you angry because i was the one that said you are the misinformed one who said that exhausts are a waste of money? considering that you're post made the least bit of sense, and that you made some kind of reference to brokeback mountain...well, i really have some doubts of your credibility. seeing that you only have a 8 posts on HT, i would recommend you prohibit yourself from this forum, and better yet, pretend that you've never heard of s2ki, we def don't need you there
Old Feb 28, 2006 | 04:34 AM
papa5murf's Avatar
Default Re: (Ponis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ponis &raquo;</TD></TR><TR><TD CLASS="quote">Noob to gears... period... but doesnt that effect highway driving..????</TD></TR></TABLE>
yes it does effect it.. it also effects your fuel mileage and your top speed
Old Feb 28, 2006 | 06:33 AM
Francesco's Avatar
Default Re: (Ponis)
they affect more than just highway
Old Feb 28, 2006 | 07:10 PM
Hi my name is simbadogg....just like the movie lion king. I suck at life and my girlfriend broke up with me because i play halo to much. I would rather drive a warthog instead of my s2k. I know everything there is to know about a s2k thats why i yes am the shiznit nicca! Thats all I have to say !
Old Feb 28, 2006 | 11:47 PM
SimbaDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llllAP1llll &raquo;</TD></TR><TR><TD CLASS="quote">Hi my name is simbadogg....just like the movie lion king. I suck at life and my girlfriend broke up with me because i play halo to much. I would rather drive a warthog instead of my s2k. I know everything there is to know about a s2k thats why i yes am the shiznit nicca! Thats all I have to say !</TD></TR></TABLE>
Cool... good synopsis mr e-thug
Old Mar 1, 2006 | 04:21 AM
papa5murf's Avatar
ROFL
BoostedH23a1
Honda S2000
20
Jun 13, 2003 11:11 AM
integracivic94
12
Jun 3, 2003 10:35 AM
AZHottie
Jan 14, 2003 05:41 AM
SIK IN DA HED
Jun 27, 2002 08:27 AM
Knightsport
Nov 6, 2001 01:48 PM
