Blue smoke under pressure
Old Feb 26, 2006 | 01:58 PM
musclefella's Avatar
Default Blue smoke under pressure
Well i've been driving under low boost for about 1500 miles(10psi) on a built block but i went tuning the car last saterday and really opening her up. We went to about 16 psi on pump gas and the car was flying i was loving it off course, but in the mirror in boost condition i see clouds of blue smoke in the distance.
http://www.surrealperformance.nl
I'm running -4an line to an oil cooler and from the oil cooler a 6inch -3an line to the turbo. Is this the reason why it's smoking??
No smoke while idle
No smoke while cruising
No smoke when accerating normally
Smoke went flooring it, and stops when letting off.
Any ideas are welcome
Old Feb 27, 2006 | 05:25 AM
Default Re: Blue smoke under pressure (musclefella)
bump
Old Feb 27, 2006 | 05:33 AM
mgags7's Avatar
its most likely bad piston rings, though it could be something inside the snail....but i wouldnt know about that
Old Feb 27, 2006 | 05:34 AM
brolli's Avatar
well...blue smoke means ur burning oil ya no....so ur burnin oil. usually means your rings are bad. iether that or your valve seals. maybe your turbo system isnt set up correctly and your pressurizing the crank case forcing oil through the valve seals or rings. just a guess.
Old Feb 27, 2006 | 11:20 AM
Default Re: Blue smoke under pressure (brolli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brolli &raquo;</TD></TR><TR><TD CLASS="quote">well...blue smoke means ur burning oil ya no....so ur burnin oil. usually means your rings are bad. iether that or your valve seals. maybe your turbo system isnt set up correctly and your pressurizing the crank case forcing oil through the valve seals or rings. just a guess.</TD></TR></TABLE>
No the car has perfect compression and there is NO oil coming from the valve cover outlet. No oil on the PVC side and NO oil on the valve nipple side. The car isn't smoking when idling and not smoking when revving up.
I'll do another compression test soon, but i know for sure it's not the rings. Here is a vid of my car at Low quality, the video image is a bit laggy so your not really experiencing how fast the car is, i'll shoot another movie soon. In this vid at the end you see me make a run and you see the bleu smoke. There is some other oil lekkage cause not all the blue smoke is coming from exhaust, but from the center of the car. Just check the vid.
http://www.2nb6.com/vids/musclefella.wmv
http://www.2nb6.com
Any advice is still welcome
B18cFreak
Apr 17, 2007 02:04 PM
CRXdan
Sep 13, 2005 12:54 PM
codyb13
Jun 16, 2005 08:47 AM
T25So
Sep 8, 2004 11:39 AM
Cyber ITR
Jan 7, 2002 05:10 PM
