88' civic D15B2 swap to D16Z6 need some help!!
Old Feb 25, 2006 | 05:23 PM
josh95mx's Avatar
Default 88' civic D15B2 swap to D16Z6 need some help!!
well iv been searching the forum for days now trying to find out what i need but no luck.
so i have a 88' civic that had a D15b2. took it out threw in a D16z6. i got a 88' CRX SI wiring harness for MPFI, then i have a PR3 ECU to run with it. well i have a couple of questions.
-is their an OBD 0 distributor to use with a Z6 head? cause mine wont bolt up without some moding of a bracket.
-seccond do i need the resistor box for the MPFI, i thought i had gotten one with my SI harness but i cant seem to locate it. i just need to know so i can locate a new one if needed.
i read that everyond said to go OBD 1 but i already bought this stuff and just want to get it working, with what i have. any help is greatly appreciated, if their is anything else anyone can think i might need please let me know.
Thanks
Old Feb 25, 2006 | 07:13 PM
josh95mx's Avatar
Default Re: 88' civic D15B2 swap to D16Z6 need some help!! (josh95mx)
bump
things move fast on this forum
Old Feb 26, 2006 | 11:58 AM
josh95mx's Avatar
BUMP
anyone?
Old Feb 26, 2006 | 01:28 PM
solfly's Avatar
the z6 distributor is the only one that bolts to the z6 head
Old Feb 26, 2006 | 01:35 PM
Chiovnidca's Avatar
Default Re: 88' civic D15B2 swap to D16Z6 need some help!! (solfly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solfly &raquo;</TD></TR><TR><TD CLASS="quote">the z6 distributor is the only one that bolts to the z6 head</TD></TR></TABLE>
Will that work with an obd0 ecu?
Old Feb 26, 2006 | 02:21 PM
josh95mx's Avatar
so my question now is, can i swap out the OBD0 distributor inturnals into a z6 distributor. or convert the Z6 dist to work on the OBD0.
Old Mar 8, 2006 | 08:42 PM
solfly's Avatar
you can kinda bolt up the a6 dist with bolts and washers
or you can supposedly change the internals
TunerKid4lyf
Jun 6, 2013 03:25 AM
kgard
Nov 5, 2005 12:40 AM
Amf_crx
Mar 20, 2004 02:52 PM
94turbolude
Jun 17, 2003 04:06 PM
