How wide can DC5's go?
Old Feb 25, 2006 | 02:25 PM
SJcivic's Avatar
Default How wide can DC5's go?
Hey guys,
Ive been searching around and I cant find anything that says how wide of wheels we can run without rubbing. Im sure suspension mods will dictate who wide we can go, so if anyone knows in general (or more specifically with Eibach Pro's) whats the limit we can go?
Rich
Old Feb 25, 2006 | 02:57 PM
DC5ITR329's Avatar
Default Re: How wide can DC5's go? (SJcivic)
it all depends on drop and camber. if they are pretty close to stock specs then 17 x 8
Old Feb 25, 2006 | 04:59 PM
SJcivic's Avatar
Default Re: How wide can DC5's go? (aznbo1626)
According to CRSX, Pro-kit Eibachs drop:
Front: 1.0 in
Rear: 1.4 in
Im probably going to use -1* front camber and -.5* on the rear.
Would this be enough to squeeze 8's under the fenders?
Would rolling the fenders prove beneficial?
Rich
Old Feb 25, 2006 | 05:13 PM
sdcivic549's Avatar
The bigger factor will be your offset and tire width. You ought to be fine with a 225 width tire without rolling the fenders, but 235's can be a bit iffy depending on the tire and sometimes rub a tad at full lock.
Old Feb 25, 2006 | 05:19 PM
The HamsterBall's Avatar
Default Re: (sdcivic549)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdcivic549 &raquo;</TD></TR><TR><TD CLASS="quote">The bigger factor will be your offset and tire width. You ought to be fine with a 225 width tire without rolling the fenders, but 235's can be a bit iffy depending on the tire and sometimes rub a tad at full lock.</TD></TR></TABLE>
you might as well buy a 7.5'' or 7'' wide wheel in that case then, with a good offset (lower than 40mm), because you can run 225's on 7'' wide wheels.
No point in paying more for a wider wheel if you're going to stretch tires on it
Old Feb 26, 2006 | 06:52 AM
96 SOHC VTEC's Avatar
On the 05 & 06's the stock rim width is already 7", so I would imagine you could run 8" depending on your ride height.
Old Feb 26, 2006 | 07:55 AM
sdcivic549's Avatar
Run the 8 inch, especially if you're not running super stiff sidewalls, it'll help with a stable contact patch.
Old Feb 26, 2006 | 11:04 AM
RsxVengeance's Avatar
you can go as wide as 9. depend on the offset of course.
Old Feb 27, 2006 | 03:22 PM
SJcivic's Avatar
Default Re: (RsxVengeance)
You all have been helpfull so far, and you all mention offset... for suning 8's what offset should I be looking for to stay-nonrubbing?
Rich
Old Feb 27, 2006 | 09:33 PM
silver comet's Avatar
im dropped to a 1 finger gap with 18x8 and a 225 tire fine w/o rubbing. I want a wider tire but i think i may have slight rubbing issues.
dannythewonder
Honda S2000
Sep 20, 2010 11:19 AM
BRIANxJDM
Honda S2000
Jul 6, 2009 05:58 AM
MikeFabRex
Jan 8, 2007 06:54 AM
S2KJ55
Honda S2000
10
Dec 29, 2006 10:07 AM
sniggler316
Jun 15, 2006 06:36 PM
