Honda S2000 Honda S2000
Will this offset work....thanks
Old Dec 25, 2006 | 06:19 AM
S2KJ55's Avatar
Default Will this offset work....thanks
5Hx114.3 @ 17x7 +35 17x8 +35. Tires Bridgestone 235/45 255/40 20-30% tread life. for my s2k ap1
Old Dec 25, 2006 | 06:34 AM
sixsixsix's Avatar
OneWayHighway
Default Re: Will this offset work....thanks (S2KJ55)
they will but not with those tire sizes. id go with a 215/245. may need to roll rear fenders though.
Old Dec 25, 2006 | 08:52 AM
iam7head's Avatar
Default Re: Will this offset work....thanks (sixsixsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixsixsix &raquo;</TD></TR><TR><TD CLASS="quote">they will but not with those tire sizes. id go with a 215/245. may need to roll rear fenders though.</TD></TR></TABLE>
it's gonna stick out a tad, not sure will fit with the slightest drop
Old Dec 25, 2006 | 09:29 AM
- BSeRiouS -'s Avatar
Default Re: Will this offset work....thanks (iam7head)
Yes those offsets will work, but they are a tad on the aggressive side.
Seriously, your best bet is to run:
225 Rear
205 Front
You CAN run a 245 for your liking for the rear, but they will have no stretch what so ever on that 8 and will stick out a tad out the fender. That is unless you run some pretty aggressive negative camber, or your car will not be very low
Old Dec 25, 2006 | 10:29 AM
Francesco's Avatar
Default Re: Will this offset work....thanks (OBSeRiouSo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouSo &raquo;</TD></TR><TR><TD CLASS="quote">Yes those offsets will work, but they are a tad on the aggressive side.
225 Rear
205 Front
You CAN run a 245 for your liking for the rear, but they will have no stretch what so ever on that 8 and will stick out a tad out the fender. That is unless you run some pretty aggressive negative camber, or your car will not be very low</TD></TR></TABLE>
Listen to OBS
what kinda rims you buying?
Old Dec 25, 2006 | 11:10 AM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
Listen to OBS
Listen to the man.
Old Dec 25, 2006 | 12:32 PM
silentdancer's Avatar
i ran 17x7.5, 17x8 + 35 before and with a 235 in the rear the tire sat right at the edge of the fender. even with fender rolling i still would of had rubbing problems. (that was with my azenis though, they run wide)
Old Dec 25, 2006 | 08:59 PM
S2KJ55's Avatar
blitz type 1
Old Dec 25, 2006 | 09:16 PM
Default Re: (S2KJ55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">Listen to OBS</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Listen to the man </TD></TR></TABLE>
Thank you for the vouches hemmie's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KJ55 &raquo;</TD></TR><TR><TD CLASS="quote">blitz type 1</TD></TR></TABLE>
ah. I fricken knew it. lol
Although, it might be a tad bit harder to find, try and scoop up the rarer Blitz Type 01, in the 17x8, 17x9 +45 all around. It is still slightly aggressive, but there is plenty of play and different options you can do with these offsets. If you do indeed find the 17x8, 17x9 +45's, you can run:
Rolled Rear Fender:
245/40-17 Rear and 215/45-17 Front
Stock Rear Fender:
235/40-17 Slightly Stretched Rear and 215/45-17 Front
Old Dec 28, 2006 | 10:24 PM
Default Re: (OBSeRiouSo)
also, just some fyi
PM "s2khic" on honda-tech. He is selling a set of these in the rarer offsets
Old Dec 29, 2006 | 10:07 AM
* B A N N E D *
How's the hub bore? He could just run the 17x8 +45 in the back.
BRIANxJDM
Honda S2000
Jul 6, 2009 05:58 AM
hmongyaj87
Jun 28, 2008 09:52 AM
J.nguyen
Honda S2000
Feb 14, 2008 04:17 PM
kyeguy82
Honda S2000
Oct 7, 2006 02:01 PM
Mr. Lucky
Honda S2000
18
May 31, 2005 06:09 PM
