Installed Tanabe Ultra Medallion, now getting black smoke. suggestions?
Old Feb 25, 2006 | 01:08 PM
SubliminalMsger's Avatar
Default Installed Tanabe Ultra Medallion, now getting black smoke. suggestions?
Hey Guys, I just installed the Tanabe Ultra medallion about a week or so ago. I love it. But now i'm noticing some black smoke when I rev. I can't notice it while i'm driving, but if i have a friend rev it i'll see little puffs of black smoke from the exhaust. I'm also noticing that my rear bumper is getting dirty a lot faster with little black specs all over.
I've done a little bit of searching but can't really find any answers. Some people say that happends when the engine is running too rich. Is there anything else I can check? I've heard some people to check the spark plugs. What would I be looking for if i do?
Aaaalso I've been noticing a quiet gurgle/clicking sound from the front (it was doing that before i installed the exhaust). I haven't looked into it much yet, but it almost seems like it's coming from the alternator. Any ideas on what that could be? Could it be contributing to my black smoke problem?
Any help is greatly appreciated!!
Old Feb 25, 2006 | 02:57 PM
Boarderx192's Avatar
Default Re: Installed Tanabe Ultra Medallion, now getting black smoke. suggestions? (SubliminalMsger)
Where are you located? How does your cat look? Is it gutted?
Old Feb 25, 2006 | 03:44 PM
machine4321's Avatar
black is usually i sign of fuel . and most ludes tend to run rich around the crossover point .
mine always had black smoke till i tuned it
Old Feb 25, 2006 | 03:56 PM
Jordans95si's Avatar
Default Re: (machine4321)
it can be the finish on the inside of teh exhaust, when they are new they some times have small amounts of smoke or funny smell...if it goes away in a week or two it is prolly this
Old Feb 26, 2006 | 12:24 PM
Default Re: (Jordans95si)
I'm in palm springs. The cat seems fine for all i can tell.. not getting any codes or anything.
Old Feb 26, 2006 | 12:29 PM
iLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordans95si &raquo;</TD></TR><TR><TD CLASS="quote">it can be the finish on the inside of teh exhaust, when they are new they some times have small amounts of smoke or funny smell...if it goes away in a week or two it is prolly this</TD></TR></TABLE>
I second this. When I put on my WS2, it smoked and smelled funny (not like oil or coolant or anything) for about a week. I figured it was just something burning off on the inside, and it turned out that it was. It went away and I haven't smelt it since.
Old Feb 26, 2006 | 02:50 PM
thelarkascend1ng's Avatar
i traded exhausts with a guy who had a Greddy PE on for probably four years or so. my bumper just gets dirty quick now as well, but i figure it's the result of having aftermarket (and sort of old, at that) exhaust. get the sponge/bucket out more often, i guess.
Old Feb 26, 2006 | 04:42 PM
Default Re: (silverlude15)
seafoam? what's that? Sorry, I'm still pretty newbish
Old Feb 27, 2006 | 04:10 PM
Default Re: (SubliminalMsger)
bump
Old Feb 27, 2006 | 04:57 PM
Saosinx's Avatar
seafoam is about $6 at napa/parts store. take about 1/3 put in your oil crank. 1/3 in your gas. turn car on and put 1/3 thru your pcv valve to go into all cylinders. turn off and let set for 15 minutes. turn on rev high. watch the white smoke fill the air!
Old Feb 27, 2006 | 05:09 PM
BergRacing21's Avatar
Default Re: (Saosinx)
yeah...they tend to say put it through the brake booster hose...because its the biggest vacuum hose....takes about two people one to pour it in while you keep it revving. Let it run for awhile and then shut if off for about 15-20 minutes come back rev it up, and take it for a spin shift at higher rpms (actually pretty fun cause it leaves like smoke screens) but it cleans out all the carbon buildup on the vavles and in the cylinders.
also black smoke is a sign of either to much fuel or alot of oil consumption...but try seafoam see how that works.
Old Feb 27, 2006 | 05:35 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (BergRacing21)
Back to the topic of the car spitting little black dots on the back of your car...My car does that too...I know it is from oil out of my exhaust (hasnt done it lately, because I have an aftermarket exhaust now and it sticks out a little farther than the stock) but How can I clean these spots off...It is obviously oil, But I cant seem to find anything that will get it off.
Old Feb 27, 2006 | 09:14 PM
Default Re: (AnthonyG2003)
Thanks for the replies guys.. I'll give it a shot and let you know how it turns out.
As for the oil spots, i don't have a problem getting them off with a normal wash.. might take a little elbow grease. If it's really caked on there some WD-40 should get it off pretty easy... but i don't imagine that's good for the wax/clearcoat/paint....
Old Mar 22, 2006 | 11:36 AM
HxClude's Avatar
a claybar should take off any carbon thats been sitting on your paint for awhile. Mothers and ClayMagic both work well - just make a quick trip to the local auto parts store.
Old Mar 22, 2006 | 01:43 PM
epoch707's Avatar
Default Re: (HxClude)
the black smoke is excess fuel, I got that when I installed my ws2. All ludes are tuned rich from the factory and the reduced back pressure is sending different readings to the MAS sensor, putting extra fuel to the chambers
DC2GSR808
Jul 3, 2014 06:35 PM
joehonda1129
Nov 29, 2007 02:35 PM
Ran4it2
Jun 23, 2007 04:08 PM
desert eagle
Apr 5, 2004 08:07 AM
cjames235
Jan 9, 2004 09:08 PM
