91 ef won't crank after tune up, troubleshooting help
Old Feb 25, 2006 | 10:23 AM
GarageAlchemist
Guest
Posts: n/a
Default 91 ef won't crank after tune up, troubleshooting help
hey guys.. im having an odd problem.
i did a tune up on my ef, plugs, cap/rotor, grounds, new battery terminals, alternator belt, oil, filter, and thats it.
I drove it for 5 mins and the ****** ran 200% better. Smooth as silk actualy.. then when i was at a light the rpms flucated and she died on me. Now it cranks, cha cha cha cha but won't start.
I have a small ammount of oil on the 4th firing plug. what could be wrong, and what steps can i do to start trouble shooting. Im gonna go check for spark now. Thanks
Old Feb 25, 2006 | 10:45 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: 91 ef won't crank after tune up, troubleshooting help (GarageAlchemist)
k i took out plug #4 and put it on the exhaust manifold and the chrome bolts ont eh valve cover for a ground nothing.. i think something is wrong with the ignitor, it has a small crack on it.. but that crack was there before.. i dunnnnnooo
Old Feb 25, 2006 | 10:35 PM
mahatma's Avatar
That sucks. So it cranks hard - not a charging system problem right? So you can rule out the alt belt & batt terminals as a problem. Oil/filter/plugs can't really go wrong.
I'd make sure those grounds are all nice & tight, and recheck the rotor set screw, those can be a bitch sometimes.
So you removed the whole plug to check for spark? I usually just pull the wire & use a screwdriver to ground to the valve cover but I guess that would work too??
Old Feb 25, 2006 | 10:51 PM
SiR Inspired ED7's Avatar
you sure the screw is on the rotor?
Old Feb 25, 2006 | 10:52 PM
SD_Lurker's Avatar
HT White Ops
check your dizzy. pull it off and try and pin it. if it does not spin it bad. check the ignitor as well. It sound like your dizzy for sure.
Old Mar 1, 2006 | 11:07 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: 91 ef won't crank after tune up, troubleshooting help (nicks_jdmstyle_ef9)
how can i check the ignitor/coil, also.. here's how i checked for spark, i put a breaker bar with a spark plug socket in the 4th chamber, then put a screwdriver(phillips) into the plug wire, then left about 1/4th an inch from the two, maybe shorter and cranked
cha cha cha nothing, couldn't see a spark, but this is broad daylight, i dunno...
also, i smell gas, plugs feel flooded lol
also, the rotor screw is on, rotor is fine, cap is fine only a day old
Old Mar 1, 2006 | 11:22 AM
ghost_ryder35's Avatar
why dont you just ground the spark plug on the frame right in front of the radiatior? thats what I do.
Old Mar 1, 2006 | 11:23 AM
Default Re: 91 ef won't crank after tune up, troubleshooting help (ghost_ryder35)
oh yea how many miles on the car? not that it matters or anything. Just usually the ignitor wont go. But if you dont have spark, then its prob the dizzy that went
Old Mar 1, 2006 | 01:11 PM
GarageAlchemist
Guest
Posts: n/a
i think its the coil, also replacing spark plug wires
Old Apr 19, 2006 | 03:28 PM
sauceja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">i think its the coil, also replacing spark plug wires</TD></TR></TABLE>
MY ef died at a stop sign and I pulled out the trusty manual to find testing the coil and the coil did not get good results. Went to checkers dished out 90.00 for a new coil went home installed and started right up.
Civic361
Jan 30, 2011 05:26 PM
b18efSI
Jul 6, 2010 03:11 PM
derrik52
Jun 25, 2010 08:15 PM
icanbrkurhrt
Jul 30, 2009 07:16 PM
LaosBoyz25
11
Apr 19, 2007 08:10 PM
