MAKING O2 SENSOR WIRE LONGER
Old Feb 24, 2006 | 11:33 PM
yellowjdmcrx's Avatar
Default MAKING O2 SENSOR WIRE LONGER
alrighty guys i got a 00 ex header for my car and i thought i could just cut the plug for th o2 run a longer wire and put the plug back on,well it didnt work. can some please tell how to lengthen the wire right?
thanks ppl
me
Old Feb 25, 2006 | 07:33 PM
theinfamouskonrad's Avatar
Default Re: MAKING O2 SENSOR WIRE LONGER (yellowjdmcrx)
did you solder it?
Old Feb 26, 2006 | 09:13 AM
Default Re: MAKING O2 SENSOR WIRE LONGER (theinfamouskonrad)
no,should i just solder both the wires together
Old Feb 26, 2006 | 09:33 AM
CRX MASE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowjdmcrx &raquo;</TD></TR><TR><TD CLASS="quote">no,should i just solder both the wires together</TD></TR></TABLE>
IMHO i would it would, it make a way better connection.
Old Feb 26, 2006 | 11:36 AM
Default Re: MAKING O2 SENSOR WIRE LONGER (DavilleKy)
ok guys,i soldered the wire and it seems to be working now,thnaks for your help
Old Feb 26, 2006 | 11:38 AM
si0385.'s Avatar
solder is your friend.. i gave in and went out and got a soldering iron, solder, and shrink wrap, and ill never go back to butt connectors
Old Feb 26, 2006 | 07:40 PM
Default Re: (si0385.)
yeah i already had all that b/c i used it to make my dizzy jumpers for my obd1 conversion i am going tobe doing.
Old Feb 26, 2006 | 09:23 PM
Immanuel's Avatar
You could do that OR use heat shrinking tube.
randyqnt
Oct 16, 2008 08:08 AM
RoB316
Jul 20, 2007 04:58 PM
crapanese
Nov 8, 2006 09:57 AM
JD95hatch
48
Aug 1, 2005 09:11 AM
90Hatch
May 2, 2003 03:23 PM
