'93-'94 Del Sol part needed.
does anyone here no where other than honda i can get a upper and lower power steering pump brackets for a '93-'94 Del Sol with the B16. has to be from a B16 del sol though. also would need the bolts that bolt them to the block.
i did that but i am needing that in paticular because i did a B18 integra swap and am using my civic pump. that is the only other one other than a '99-'00 civic si set of brackets that will work.
krazbiker118
Jan 8, 2009 09:30 AM
