Exhaust spring bolts? Got a question.
Old Feb 24, 2006 | 04:15 PM
mikeunreal2's Avatar
Default Exhaust spring bolts? Got a question.
Are those springs bolts that connect the header to the cat important? I lost mine, dont ask how; and was wondering if i can just run regular bolts.
Mike
Old Feb 24, 2006 | 04:25 PM
96dxpower's Avatar
Default Re: Exhaust spring bolts? Got a question. (mikeunreal2)
arent the springs there for flexibility? when the engine moves it flexes with the springs?
Old Feb 24, 2006 | 05:08 PM
Default Re: Exhaust spring bolts? Got a question. (96dxpower)
suppose to be, but does the engine honestly move enough to need them. the parts thats hanging in the hangers can move back and fourth if nescarry. anyone got any suggestions?
Mike
Old Feb 24, 2006 | 05:33 PM
Luserkid's Avatar
If you dont have a flex pipe you need those springs. Without them your going to have cracks on your header.
Old Feb 24, 2006 | 05:57 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 &raquo;</TD></TR><TR><TD CLASS="quote">suppose to be, but does the engine honestly move enough to need them.</TD></TR></TABLE>
Yes. They can't be terribly expensive from Honda, or you can try to fabricate your own bolt/spring setup. Either way, I would definitely recommend against simply bolting the header to the cat with no springs.
Old Feb 24, 2006 | 06:33 PM
cfhcar's Avatar
you can get bolt with spring from the aftermarket walker muffler list them
Old Feb 24, 2006 | 07:42 PM
EL Vap133's Avatar
Go to your local pick and pull.
Old Feb 25, 2006 | 06:48 AM
JSPECSIR's Avatar
Default Re: Exhaust spring bolts? Got a question. (EL Vap133)
carquest part #578808 (spring bolt kit)
Old Feb 28, 2006 | 02:18 PM
Default Re: Exhaust spring bolts? Got a question. (5THGENSI)
Called the dealership. This is what they told me:
Bolts...........8.00
Springs........7.00
Nuts.............4.00
Remember, all these prices are for 1 of each. So in total, i was looking at spending 40 bucks on spring bolt kits!! HOW RETARTED!! Nedless to say, carquest had what i needed.
Lifter2012
Nov 4, 2006 09:07 AM
madcrossover
Jul 1, 2006 10:31 AM
microsoft_sux
Mar 28, 2005 02:58 AM
crizmotek
Aug 7, 2002 11:22 PM
X2BOARD
Jun 26, 2002 06:14 AM
