full gsr brake swap
You don't have to do either. I wish I hadn't... Just get a good set of pads/rotors for the front and you should be straight.
But if you don't like the drum look, do the rear disc.
yeah with the rear disk swap it looks really nice.. but im just thinking would it be worth the cash to do that.. or should i just upgrade on the front brakes..
Ya man get this kit right here i have the same car but a 92 cx hatch this is what im getting on my car... http://fastbrakes.com/shop/pro...d=342 .. ITS A tight *** kit
those are huge... but no thanks.. i aint trying to pay that much cause i aint autocrossing..etc. or anything crazy.. just want to upgrade my brakes a little
yes u should, it looks good and brake better, especially with a swap u would want better stopping. it's annoying fixing your drum anyway when u could just put some pads and a disc and your done.
get the full brake swap, its well worth it. you car will stop much better than with the drums. get a 4040 prop valve and a 15/16" mc and booster from an integra rs (non-abs) also and youll be set.
Im doing my brake swap as we speak...so much work...after all said and done it wil like 600 for setup
300 for conversion+ lines
220 for new brembo blanks, hawk hps pads, brembo dot 4 fluid
90 for new 1991 4dr ex master cylinder
40 for prop valve
20 for extra fittings, tools etc
40 for prop valve
