h22a idles at 1500rpm
Old Feb 24, 2006 | 11:29 AM
Linh.'s Avatar
Default h22a idles at 1500rpm
I drive a jdm h22a hatch and on start up the car idles at around 1100rpm. I drive down the road and hit a stop and it idles at 1500rpm. Also have a skunk2 68mm tb with the stock manifold. Tried messing with the idle screw but can't make the idle drop at all. The vacuum lines were all replaced. Could I move the tps sensor a bit? Any suggestions?
Old Feb 24, 2006 | 11:31 AM
Honda Sport's Avatar
usually when adjusting idle, you unplug the iacv then turn the idle screw down. reset the ecu and it should be good.
you could also have air in your coolant system. could always try bleeding the sysytem.
Old Feb 24, 2006 | 11:33 AM
Linh.'s Avatar
Default Re: (Honda Sport)
yeah i tried taking the iacv plug out and from what i heard your suppose to get the rpm steady at 2k and then turn the screw but nothing worked.
Old Feb 24, 2006 | 11:52 AM
what you do is turn the car on, unplug the iacv connector, then turn the screw down so the idle is sitting at desired rpm(usually 750rpm). then plug the iacv back in. reset the ecu.
Old Feb 24, 2006 | 11:59 AM
94Vtecluder's Avatar
Sounds basically like a non issue to me. 1500 RPM's is a okay idling point. If it's not broken don't fix it...
Old Feb 24, 2006 | 12:11 PM
Linh.'s Avatar
Default Re: (94Vtecluder)
I did that but the idle doesnt drop as a turn the screw inwards
Old Feb 24, 2006 | 12:21 PM
*edit*
maybe you have a leak between the IM and TB. check for leaks by spraying water or brake clean. if there's a leak, there should be a slight surge in your idle.
Old Feb 24, 2006 | 12:22 PM
Linh.'s Avatar
no i have a NEW skunk2 tb but its been running at this idle for a while. Could it be the throttle body gasket?
Old Feb 24, 2006 | 12:57 PM
snowblind7x's Avatar
Default Re: (shooitslinh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shooitslinh &raquo;</TD></TR><TR><TD CLASS="quote">no i have a NEW skunk2 tb but its been running at this idle for a while. Could it be the throttle body gasket?</TD></TR></TABLE>
that's what he said. Spray some carb cleaner and see what happens
georgiajdm
Aug 11, 2009 06:31 PM
viciousef9
Jun 18, 2007 03:18 PM
duceducecord
Sep 3, 2006 05:58 PM
951dc5
Nov 21, 2004 08:23 PM
redman223
Jun 26, 2003 08:20 PM
