crank pulley
Im replacing my head gasket with a cometic,replacing head bolts with arp heads and new timing belt on my y8.
my question the is nut on the crank pulley reverse thread or not? I doesnt says in my helms and its kicking my *** right now!!
Guest
Posts: n/a
no, your nuts are not cross threaded. if you want to get it out, use an impact on that beotch and buy a can of pb blast or wd 40 and unload the whole can on it and keep using the impact at the same time, do it for about 5 min and it will spin right off.
