ls in 95 dx questions
Old Feb 23, 2006 | 09:57 PM
AJxr's Avatar
Default ls in 95 dx questions
ok so i graduated from my 90 si hatch to a 95 dx. not much of a step up but i also just picked up a complete 98 ls motor and tranny. i tried searching but i couldnt really find a good answer for what i need to know. here are my questions.
can i use my dx harness?
the integra mounts that came with the ls? (guy who sold me the swap said i could)
which axles?
need b-series linkage?
i know what you need to drop an ls into a 88-91 but im new to this newer stuff... yep.
i already have the ecu figured out. also if there is anything else i need to know please let me know. yeeeeeah
Old Feb 23, 2006 | 10:05 PM
AJxr's Avatar
Default Re: ls in 95 dx questions (SLOW guy)
so dx axles will work? can anyone confirm this? also anyone have any reccomendations on mounts aside from hasport?
Old Feb 23, 2006 | 10:11 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLOW guy &raquo;</TD></TR><TR><TD CLASS="quote">u need custon mounts, the axles should work fine or use DA axles, and the harness u might be able to use the same harnes but the dizzy and alernater may be different.</TD></TR></TABLE>
WTF?
To the original poster: SEARCH.
You are asking the most popular question; a b series swap.
Old Feb 23, 2006 | 10:13 PM
AJxr's Avatar
Default Re: ls in 95 dx questions (fast88std)
yeah, i didnt really get that to much either. if the 92-95 civic mounts differ when compared to the 94-01 teg mounts how come on hasport.com they are the same part?.... ANYONE?
Old Feb 23, 2006 | 10:17 PM
AJxr's Avatar
now im a little confused, arent 95 dx obd1? i thought pre obd civics ended in 91?
Old Feb 23, 2006 | 10:45 PM
AJxr's Avatar
can i use 94-00 integra linkage?
Old Feb 24, 2006 | 12:16 AM
fmrprojects's Avatar
Default Re: ls in 95 dx questions (AJxr)
if you got the complete swap everything will go in. its a direct swap. the only thing u need is a obd-1 p75 ecu to make it run. its a direct swap, use everything from the integra minus the ecu. hope that helps
Old Feb 24, 2006 | 12:28 AM
DSRxNATE DNRperformance's Avatar
Default Re: ls in 95 dx questions (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">if you got the complete swap everything will go in. its a direct swap. the only thing u need is a obd-1 p75 ecu to make it run. its a direct swap, use everything from the integra minus the ecu. hope that helps</TD></TR></TABLE>
well spoken!
evosix
14
May 22, 2010 08:50 PM
jdmbeegee
14
Sep 6, 2006 10:30 PM
Nicaraguense13
Aug 15, 2006 06:18 PM
JDMfrontedLS
Feb 12, 2006 07:06 PM
GDM Z28
Feb 13, 2003 02:18 PM
