MY problem of the day - Random, possessed tach needle
Old Feb 23, 2006 | 09:30 PM
99CivicSiBrian's Avatar
B A N N E D
Default MY problem of the day - Random, possessed tach needle
So I'm having tach issues.
Sometimes the tach reads normal. Other times, it shows about 1/2 what it should show. Othertimes it rests at 0 on the needle! Anybody want to take a guess as to whats going on?
I haven't tried to fix anything yet, but first I'm going to double check the plug going into the back of the cluster and make sure it's in tight. Next, check plugs on the dist. Then check grounds. My last option is to try someone elses to see if it has the same problems to determine if I have a bad tach.
Well, anyone have this issue, post up.
Thanks!
B
*edit* It's a stock 95 EX from Canada.
Modified by 99CivicSiBrian at 4:33 PM 2/24/2006
Old Feb 23, 2006 | 09:34 PM
imskatencrzy's Avatar
Default Re: MY problem of the day - Random, possessed tach needle (99CivicSiBrian)
sounds like you know what your doing.
B A N N E D
Default Re: MY problem of the day - Random, possessed tach needle (imskatencrzy)
I have some ideas, but I'm hoping to catch someone that had this problem who could pinpoint it right away so I don't waste time on some dumb **** lol.
B
Old Feb 24, 2006 | 03:17 PM
B A N N E D
Bumpity bump #1
B
Old Feb 24, 2006 | 03:23 PM
graveltravel2's Avatar
try buying a used guage cluster and see it that is the problem. you can usually get them for less than 50 bucks.
Old Feb 24, 2006 | 03:32 PM
B A N N E D
Default Re: (graveltravel2)
I had a friend recommend a new ignitor. Make sense to anyone else?
B
H22Luda720
Oct 16, 2008 07:46 PM
e-Roc
Jun 25, 2006 07:16 PM
AFAccord
Jan 3, 2006 05:30 AM
Nataku
Dec 3, 2005 07:12 PM
Mantis88ls
May 23, 2004 09:13 PM
