Car won't start... main relay? ground?
Old Feb 23, 2006 | 06:27 PM
beak's Avatar
Default Car won't start... main relay? ground?
Hey guys...
I have an H22A4 in a EJ8 (97 EX Coupe) and it won't start. Car cranks but does not start. I checked to see if the fuel pump is getting power, and it is not. Main relay is not making any noise. Could it still be bad? Where is the main relay in an EJ8....?
I also tried to see if I had a thermostat ground coming from my thermostat to a ground on the car. I did not. I added a 10 ga wire from the thermostat housing to the screw the battery ground connects to on the fender. Nothing.
Car just cranks and cranks, but makes no ticking noise, and I can't hear the fuel pump. I put in a Walbro 190 as well, brand new, hoping maybe that would solve the problem (before I tested to see if the pump got power).
So... main relay not clicking, thermostat housing grounded, and fuel pump fuse is good.
Any suggestions?
Thanks guys...
Old Feb 23, 2006 | 06:59 PM
ImportGeeK's Avatar
Default Re: Car won't start... main relay? ground? (beak)
The main relay could be your problem but also check to see.
1. If your getting spark
2. Do you have the right ecu
Also the main relay is located on the passanger side, take the glove box out and the main relay is right about the glove box and a 10mm bolt is holding it in place.
I hope this info helps you!!
Old Feb 23, 2006 | 07:04 PM
beak's Avatar
Yeah, it's getting spark. And it's the correct ECU.
Thanks!
Old Feb 24, 2006 | 06:44 AM
ImportGeeK's Avatar
Default Re: (beak)
Did you Find/Change the main relay? Update
Old Feb 25, 2006 | 05:53 PM
beak's Avatar
Default Re: (ImportGeeK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportGeeK &raquo;</TD></TR><TR><TD CLASS="quote">Did you Find/Change the main relay? Update</TD></TR></TABLE>
Thanks, the main relay fixed the problem, and brought the H22 to life
Rick Overton
33
Aug 6, 2015 07:47 PM
ckirso
Mar 18, 2013 08:08 AM
raverx3m
Sep 16, 2011 11:09 PM
justmechillin05
Mar 26, 2009 04:03 PM
beak
Feb 23, 2006 07:19 PM
