NEED HELP
the code 17 is your vehicle speed sensor and the si gauge cluster uses an electronic one while the crx uses a mechanical one , heres how to fix it locate a speed sensor off a 99 si and make sure to get the entire plug of the harness , u need to wire in 3 wires, two are colored wires (one is to wire into the ecu plug and the other is to wire into the cluster) and the third is a black wire (ground) the reason why your vtec isn't working is because for vtec to work the ecu needs singals from 4 sensors (engine speed,vehicle speed , coolant temp, manifold pressure) code 6 is your coolant temp sensor , the best thing to do is to replace it
96 GSR-T
Dec 5, 2007 12:26 PM
