lude injectors in gsr?
Honda Prelude JDM Injectors. Part # 06164-P0A-000 . would these bolt onto my 2001 gsr? i think the lude injectors come 310cc i'm not sure though. can someone help me out. would the o rings and everything fit good? what about obd2 stuff? any diff? these are from a 95 lude. i don't know if the ludes in japan are all vtec
They will fit but you need to make sure the gsr have a low impedance injector. The prelude ijectors are low impedance and yes they will fit but you may have to get a different o ring to seal the seats of the injector. Other than that you are good to go.
What ECU are you using? You should not use peak and hold injectors (92-96 H22a)with an ECU designed to drive saturated injectors (All B-series)...
https://honda-tech.com/zerothread?id=151973
Andrew
Andrew
However, the 92-96 Preludes use LOW impeadnce injectors (Peak and hold).
Andrew
they will work, to run peak and hold, all you need is a resistor box. what people dont realize is ALL honda ecu's are designed to run the saturated ones, but preludes come stock w/the resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">they will work, to run peak and hold, all you need is a resistor box. what people dont realize is ALL honda ecu's are designed to run the saturated ones, but preludes come stock w/the resistor box.</TD></TR></TABLE>\
Yes. Peak and Hold type with resistor box, saturated without. Ecu does not matter.
I run RC Peak and Holds with a resitor box and a GS-R ecu so there!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">\
I run Peak and Holds with a resitor box and a GS-R ecu so there!</TD></TR></TABLE>
ditto
ditto
Im more curious about why you would need 310 injectors on a GSR.
If the mods you have are just a simple i/h/c/e then you would actually lose efficiency from 310s. Maybe a VAFC would be a better Idea to spend the money on... so this way you would be able to lean it out instead of using the Old-V8-Mullet-Rocking Saying of "more fuel more power no matter what".
No offence if your a redneck, but There really is no Point to 310s if you dont have the mods to call for it.
