lude injectors in gsr?
Honda Prelude JDM Injectors. Part # 06164-P0A-000 . would these bolt onto my 2001 gsr? i think the lude injectors come 310cc i'm not sure though. can someone help me out. would the o rings and everything fit good? what about obd2 stuff? any diff? these are from a 95 lude. i don't know if the ludes in japan are all vtec
Re: lude injectors in gsr? (batboyvaj)
They will fit but you need to make sure the gsr have a low impedance injector. The prelude ijectors are low impedance and yes they will fit but you may have to get a different o ring to seal the seats of the injector. Other than that you are good to go.
New User
What ECU are you using? You should not use peak and hold injectors (92-96 H22a)with an ECU designed to drive saturated injectors (All B-series)...
https://honda-tech.com/zerothread?id=151973
Andrew
Andrew
New User
Re: lude injectors in gsr? (H22g2Integra)
However, the 92-96 Preludes use LOW impeadnce injectors (Peak and hold).
Andrew
Re: lude injectors in gsr? (prelittlelude)
they will work, to run peak and hold, all you need is a resistor box. what people dont realize is ALL honda ecu's are designed to run the saturated ones, but preludes come stock w/the resistor box.
Re: lude injectors in gsr? (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">they will work, to run peak and hold, all you need is a resistor box. what people dont realize is ALL honda ecu's are designed to run the saturated ones, but preludes come stock w/the resistor box.</TD></TR></TABLE>\
Yes. Peak and Hold type with resistor box, saturated without. Ecu does not matter.
I run RC Peak and Holds with a resitor box and a GS-R ecu so there!
Re: lude injectors in gsr? (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">\
I run Peak and Holds with a resitor box and a GS-R ecu so there!</TD></TR></TABLE>
ditto
ditto
Im more curious about why you would need 310 injectors on a GSR.
If the mods you have are just a simple i/h/c/e then you would actually lose efficiency from 310s. Maybe a VAFC would be a better Idea to spend the money on... so this way you would be able to lean it out instead of using the Old-V8-Mullet-Rocking Saying of "more fuel more power no matter what".
No offence if your a redneck, but There really is no Point to 310s if you dont have the mods to call for it.
