Headlight/Tail-lights problems
Old Feb 23, 2006 | 01:45 PM
TapOrSnap's Avatar
Default Headlight/Tail-lights problems
I searched as much as I could finding no answers to my problem. My headlights do not work. But I found that if I squeezed or moved around this amber colored looking plug (in the center of the picture), then the lights would work. This however, does not do the trick anymore. The tail lights also do not work, but if I press the brakes, the brake lights come on. Hazards are working fine.
So I figured it might be a loose connection in the plug, so I cut the plastic covering off and inspected the wires/pins. Everything looked fine. All of the fuses are good. I am just puzzled and frustrated at this point. Any helpful info would be greatly appreciated.
Old Feb 23, 2006 | 01:48 PM
Pee Wee's Avatar
Default Re: Headlight/Tail-lights problems (TapOrSnap)
bump because my passenger side highbeam wont work and i cant figure it out
Old Feb 23, 2006 | 02:00 PM
crx_88_si's Avatar
Default Re: Headlight/Tail-lights problems (Pee Wee)
go to your headlights and test if they are getting 12v. (test voltage between + lead and body ground.) if that tests ok then that means there are no brakes in the wire for the + side.
next test ground. get a jumper wire and wire the - side to the chassis. If the headlights work then trace the oem - wire for brakes.
you may have to do this for 1 or more of the headlights.
Old Feb 23, 2006 | 02:09 PM
TapOrSnap's Avatar
Default Re: Headlight/Tail-lights problems (crx_88_si)
So, do you think the problem has anything to do with the plug?
Old Feb 23, 2006 | 03:09 PM
Mr_ET's Avatar
you low light may be burnt out in your rear lights happens a lot for our models maybe change them out and see if t helps the tail lights
Old Feb 23, 2006 | 03:15 PM
TapOrSnap's Avatar
Default Re: Headlight/Tail-lights problems (Mr_ET)
do you mean to say that if a tail light bulb is out, then the headlights will be affected? and vice versa?
HpTeggy98
Dec 13, 2016 02:14 PM
Rizzen
Aug 28, 2008 07:08 AM
97BB6Type-SH
Nov 16, 2007 04:06 AM
