Smoke, at shift. What needs to be fixed?
Old Feb 23, 2006 | 07:03 AM
THC07's Avatar
Default Smoke, at shift. What needs to be fixed?
I have an issues. i dont like to be on the track and have smoke shooting out my exhaust when i shift. it only comes out at a high RPM, seems to come out when i put the clutch down to shift.
what is it that i need to fix?. i hope its just something in the head like valve guides.
Old Feb 23, 2006 | 08:10 AM
SicilianSpeed42's Avatar
Default Re: Smoke, at shift. What needs to be fixed? (THC1107)
what color smoke?
Old Feb 23, 2006 | 08:39 AM
THC07's Avatar
Default Re: Smoke, at shift. What needs to be fixed? (SicilianSpeed42)
blueish. its gotta be oil. i consume about 1 qrt in 3-4 weeks
Old Feb 23, 2006 | 08:40 AM
turbosnatch's Avatar
usually that would be rings, doesnt mean they will go soon but are getting old
Old Feb 23, 2006 | 08:44 AM
THC07's Avatar
Default Re: (turbosnatch)
its a D15B tec with only 50,000 miles one it. Rings already?
Old Feb 23, 2006 | 09:07 AM
94hatchling's Avatar
could either be a leaking valve guide seal, leaking valve cap, or something else valve/head related that is allowing oil to get into the combustion chamber. OR a bad ring.
run a compression test and a leakdown test to pinpoint this more before you start tearing down your motor.
Old Feb 23, 2006 | 11:36 AM
Default Re: (94hatchling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling &raquo;</TD></TR><TR><TD CLASS="quote">could either be a leaking valve guide seal, leaking valve cap, or something else valve/head related that is allowing oil to get into the combustion chamber. OR a bad ring.
run a compression test and a leakdown test to pinpoint this more before you start tearing down your motor.</TD></TR></TABLE>
good response
Old Feb 23, 2006 | 08:22 PM
THC07's Avatar
I have Great compression. the smoke is only at a high rpm (7000) and only after i shift. smokes only for a second. like its getting a sip of oil. if it were the rings it would smoke all the time after vaccum. right? is there a How To write up on replacing your valve guides?
Could it be rings with this kinda symptom.
is there a way to check your guides?
builtITRm22x
10
Sep 22, 2008 08:09 PM
EK FLY
Jul 1, 2007 02:52 PM
huepowered
Apr 4, 2006 12:10 PM
turbo95eg6
Jul 10, 2005 07:22 AM
type Gendy
15
Sep 26, 2003 02:15 PM
