integra muffler on EK hatch? Please help
Old Feb 22, 2006 | 09:31 PM
eternal780's Avatar
Default integra muffler on EK hatch? Please help
Im a NuuuB ....hey guys i have a integra muffler on my ek and whenever i make aright turn it seems that the muffler is hitting something. Does the integra muffler fit an ek or do i need a civic si muffler. It seems that the muffler is really close to the crossmember like about 1 inch away. Anything i can do thanks please help.
Old Feb 22, 2006 | 09:37 PM
Turbo_y8's Avatar
Default Re: integra muffler on EK hatch? Please help (eternal780)
its prolly hte piping hit the control arm.
Old Feb 23, 2006 | 07:21 AM
sohc'd upEJ8's Avatar
Default Re: integra muffler on EK hatch? Please help (tuck'd98)
If you want a quick fix.....Take a piece of rubber or an old radiator hose and cut it to fit where the exhaust is touching......Zip tie it or use metal wire(even like MIG wire could work) and tie it up....My friend did it on his GSR with a spoon exhaust meant for an EK and it worked......Good luck
Old Feb 23, 2006 | 07:46 AM
infulleffect's Avatar
Your pipe may also be hitting the hanger that is back there...the bend for an Integra is not sharpe enough for the EK hatch.
Old Feb 27, 2006 | 09:15 PM
eternal780's Avatar
yea i was looking at it and it seems the top left corner of muffler is hitting the corssmenber and the front bottom is hitting the peice of metal that looks like a dust shield for the rear breaks.So should i move the muffler back alittle ?
Old Feb 27, 2006 | 09:56 PM
powerfulperformance's Avatar
Default Re: (eternal780)
i have an itr muffler and piping on my ek. All i did was cut off the hanger and weld it to the back of the muffler. I also had to cut the tip because it sticks out alot on an ek...
Old Feb 28, 2006 | 02:12 PM
eternal780's Avatar
kool ima think ima have the muffler shop do that. So definately its the hangers then correct. just cut it and weld it to the back then ? kool thanks i will update when i ave it done
Old Feb 28, 2006 | 02:29 PM
BudgetBalla's Avatar
hi, i have a gsr muffler on my ek hatch. The piping for the axle-back portion had to be cut and rewelded. The tip part had to be shortened. It is a very tight fit, the muffler cannot be perfectly centered, as the spare tire well gets in the way. It is maybe 5 degrees offset to the passenger side. I would recommend another muffler, even though it sounds really quiet.
Old Feb 28, 2006 | 03:40 PM
eternal780's Avatar
yea im running the gsr muffler with tanabe piping. I have the tanabe but its hella loud. So i kinda want to keep the stock. Im sure there is a way to make that b*tch fit hahaha thanks though. Will a Si muffler fit?
jake_poww
Oct 22, 2017 06:54 AM
redlineryder
Aug 20, 2008 05:50 PM
Killa From Manila
Oct 16, 2007 09:10 PM
blindsk8er1013
Jun 18, 2007 08:53 AM
BiziggumS
13
Aug 29, 2004 03:53 PM
