loose timing belt -searched
Old Feb 22, 2006 | 07:54 PM
h22vt's Avatar
Default loose timing belt -searched
i have a 01 prelude that i just put a new motor in (water+cai=bad)and i was having my values adjusted at a different garage than who put the motor in. while they had my cover off they said my timing belt was very loose. so i took it back to the garage that just did my swap and they said it was fine. how loose should it be?
Old Feb 22, 2006 | 09:06 PM
NeriVTEC's Avatar
Default Re: loose timing belt -searched (h22vt)
Just adjust it with the tensioner if it is a manual one.
Old Feb 23, 2006 | 03:31 AM
h22vt's Avatar
thanks but i need to know how loose it needs to be.
Old Feb 26, 2006 | 08:25 AM
b18hondaacura's Avatar
Default Re: (h22vt)
i need to know too.
Old Mar 10, 2006 | 08:36 AM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
After loosing the acorn nut on the tensioner let the tensioner and spring do all the work... tension should be on the pull side and slack should be on the tensioner side. Do this at TDC... to check you should be able to bend the timing belt 90 degrees so that it is facing you with your fingers. If its really easy or goes past that its to loose. If its ridiculously hard then its to tight.
Timing belts can be a pain but for a honda its all in the tensioner so you shouldnt have to do anythin major for adjustment.
Old Mar 10, 2006 | 09:46 AM
98TypeSH's Avatar
Default Re: loose timing belt -searched (ForceFed_Motorsports)
what type of motor was put in ? JDM ? USDM ? eaither way, it has an auto tensioner. Maybe you should replace it before it takes a fat **** on you. Manual conversion or buy a new auto.
soodominican
Oct 12, 2008 08:59 PM
h22mark
Apr 25, 2007 07:44 AM
Greg123
Mar 18, 2003 05:59 PM
johnzm
Jun 16, 2002 06:56 PM
KoRE
Jun 15, 2002 09:27 AM
