any one have a guess on price?
alright i have a 90 hatch std and i want to eather do a b18c1 (GSR) swap or a B16 swap. im not sure on how much it will cost about. i know that there are alot of people on here who have done the swap. any help on a guess on the price will help. thanks.
mainly depends on where you get the motor. average ive seen is $2000-3000. the majority of that is spent on the motor and transmission itself. then little things add up like a timming belt, plugs, wires, cap, rotor, water pump, clutch, flywheel and maybe even replacing the valve cover gasket. just basic maintince to the motor so you wont have to worry about it for a while after you drop it in.
30001 - B16A 88-91 (SiR I) Motor, Tranny, Computer
160Hp 111Trq 10.2 Compression (JDM)
$ 1250.00 Plus shipping and handling.
30009 - B18C 94-97 (GSR) Complete Change Over
180Hp 126Trq 10.6 Compression (JDM)
170Hp 121Trq 10.1 Compression (USDM)
$ 3149.00 Plus shipping and handling.
Those are from hmotorsonline.com
Hasport
Mounts $399.20 (B Series)
Swap axles $399.00 (B Series)
Shift Linkage $150.00
So around 950 for mounts, axles, and linkage. Then the price for the motor that you choose. With a b16 it will be easier to wire because it is obd0. The gsr is obd1. You would have to convert up to obd1 for the gsr. That should kind of give you an idea
Hasport
thanks for the help guys. so it looks like im about half way there on the money. just one more quesstion. to put in the b16. i konow i have to do some rewireing. but how hard is it to rewire for it. REMEMBER ITS A STD. wouldnt i need the SI harnes?? once aggain thanks guys. im really deciding weather to put this money in this car or sell it and get somthing newer.
I don't know if I would put that much into a car that I bought for $100.00. Is it in good shape or needs a lot of work? Chances are you can find a car with the motor you want for less than it will cost you to build your $100.00 car. Don't get me wrong, you may have gotten a great car for the money and it may well be worth the $ to do a swap. Reguardless it's your call. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood »</TD></TR><TR><TD CLASS="quote">I don't know if I would put that much into a car that I bought for $100.00. Is it in good shape or needs a lot of work? Chances are you can find a car with the motor you want for less than it will cost you to build your $100.00 car. Don't get me wrong, you may have gotten a great car for the money and it may well be worth the $ to do a swap. Reguardless it's your call. Good luck.</TD></TR></TABLE>
buying other people's creations usually ends in disaster. I like knowing that my car was put together properly, by myself, and not someone else. Alot of people here would probably tell you that.
I also take pride in telling people that my engine is worth WAY more than my car.
well dont think too hard about the 100 this is the car when i was done fixing it. i bought it off a friend who worked for an insurance company. it was totaled but i got it before the salvaged the title. it has a clear title and this is what it looks like today. im only in to it about 500 bucks...
