jdm h22a, how to tell exactly what year and what dizzy cap do i use???
Old Feb 22, 2006 | 04:46 PM
twistedbydezign's Avatar
Default jdm h22a, how to tell exactly what year and what dizzy cap do i use???
like title says, i know the usdm h22a1 dizzy cap doesnt work, so what cap do i use from what car/engine/year??? also, i know stuff varies on the obd I h22 between 92 and 95, so how can i tell exactly what year the engine is??? ive heard of the crank pulley bolt being different and i think the pcv valve is different, what can i measure to be sure???
thanks
Old Feb 22, 2006 | 07:07 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default Re: jdm h22a, how to tell exactly what year and what dizzy cap do i use??? (twistedbydezign)
I know where you can find the year of the engine. It's in between the 1 and 2 header (I think) maybe 3 and 4th header, but anyway it's between one of the headers. So you have to remove the heat shield and there's a clock like symbol with and arrow. The #'s on the clock are the months of the year i.e if the arrow is pointing at the 2 then it's February. There's a # in the middle of the clock and that's the year of the engine, however if the arrow is pointing at 6 (June) or more then you add 1 year to what the # of the middle is. For mine it said 92 in the middle of the clock, but the arrow was pointing at 6 so the year of the engine is a 93. I could be wrong, but that's how I found out.
Old Feb 22, 2006 | 09:36 PM
M2B4's Avatar
Default Re: jdm h22a, how to tell exactly what year and what dizzy cap do i use??? (mozzandherb)
did they make the 92's in japan with h22? did they have a jdm f22 non si modle like we did?
Old Feb 22, 2006 | 11:11 PM
petern101's Avatar
Default Re: jdm h22a, how to tell exactly what year and what dizzy cap do i use??? (M2B4)
h22a jdm vtec's came out in japan in '91
when you did the swap. you either should have re-used h23 dizzy/external coil or you probably need to buy a usdm one, its just easier to find stuff that way
Old Feb 23, 2006 | 07:44 PM
Default Re: jdm h22a, how to tell exactly what year and what dizzy cap do i use??? (petern101)
bump, still trying to find out which dizzy cap i can use...
Old Feb 24, 2006 | 01:03 AM
External, I got one from a local dealership
Old Feb 24, 2006 | 05:46 AM
kulrevon's Avatar
do you have an internal dizzy or external?
Modified by kulrevon at 9:58 AM 2/24/2006
Old Feb 24, 2006 | 06:52 AM
SpeedFreak77's Avatar
Default Re: jdm h22a, how to tell exactly what year and what dizzy cap do i use??? (kulrevon)
My JDM H22 (92) is an internal coil and I used a cap from a newer Civic Si I believe the guy gave me one from a 99 or 2000. If you have the old one take it in with you and compare just have the shop pull a few off the shelf.
Old Feb 24, 2006 | 11:40 AM
Honda Sport's Avatar
you can use a 90-93 accord dizzy cap. I did on my JDM h22a dizzy.
Old Feb 24, 2006 | 01:24 PM
Cottonwoodz's Avatar
What, petern101 said.......
Old Feb 25, 2006 | 07:08 PM
petern101's Avatar
Default Re: (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">What, petern101 said.......
LOL amen brotha
honestly did he not read my response? why do ppl always try to make stuff hard?
Old Feb 25, 2006 | 09:17 PM
Default Re: (petern101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL amen brotha
honestly did he not read my response? why do ppl always try to make stuff hard?</TD></TR></TABLE>
having to go out and buy a whole new dist and convert the jdm internal coil dist thats been in the car for 2 years back to external is the easy way??? if the civic si dist cap works on the internal h22a like someone said i would say that is easier
Old Feb 25, 2006 | 10:26 PM
petern101's Avatar
Default Re: (twistedbydezign)
well i meant by not changing the thing in the first place
it is a much better option to do it during the swap. if you didn't do the swap, then maybe i can see why it would be a bit more of a problem. there is no benefit from keeping the internal distributor while making it into an external distributor is.
Old Feb 27, 2006 | 06:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">
having to go out and buy a whole new dist and convert the jdm internal coil dist thats been in the car for 2 years back to external is the easy way??? if the civic si dist cap works on the internal h22a like someone said i would say that is easier</TD></TR></TABLE>
it's not hard at all. all you do is take off the old dizzy, put on the h23a1, find a place to put the coil, set timing, you're set!
like I said earlier, if you want to keep your internal coil dizzy, you can use a 90-93 accord cap also.
Tippyman
Apr 8, 2010 10:57 AM
casting.shadow
Nov 5, 2009 04:44 AM
rentien
Nov 23, 2003 11:16 AM
Jonathan_ED3
Oct 21, 2002 12:53 AM
suncoastcustoms
Aug 14, 2002 05:56 PM
