Engine code .,??help.,
Old Nov 4, 2009 | 02:07 PM
casting.shadow's Avatar
Default Engine code .,??help.,
Well question is.,
just bought a 90' accord with h22a motor swap.,.trying to figure out what year.,.,or how much power the h22 has.,???.,so what is the meaning of the 7 digit number following the h22A.,
read alot of threads and reaaly compfused.,.,help.,.,.,
Old Nov 5, 2009 | 01:07 AM
EKSiR99's Avatar
Default Re: Engine code .,??help.,
jdm h22a puts out 180-185 WHP
Old Nov 5, 2009 | 04:44 AM
nus_dogg's Avatar
If you have an aftermarket stainless steel or ceramic header, you should be able to see the year of the engine. Its on the head where the header bolts to; can't miss it. You should see two numbers there.
The H22s are rated at 200bhps and 161tq at the crank. A healthy H22 can produce 150-170whp depending on the condition of the motor.
pkolaboy
May 11, 2008 09:20 PM
drew1987
Apr 15, 2008 07:28 AM
ekslammed
May 22, 2007 12:13 PM
stuckn
Feb 6, 2007 06:23 PM
PreludePhill
Jun 11, 2006 10:37 PM
