were this ground goes ??
Old Feb 22, 2006 | 03:40 PM
redeg61987's Avatar
Default were this ground goes ??
i was putting brake fluid in my car today and i notcied this ground was discontected i want to know if any of you guys new were it goes so i can connect it agian thank you
Old Feb 22, 2006 | 03:47 PM
b00st Junkie's Avatar
TOASTYYY!!
Default Re: were this ground goes ?? (redeg61987)
there is a bolt that it mounts to on the valve cover. i dont see it the pic though
Old Feb 22, 2006 | 03:49 PM
. a d a m's Avatar
Default Re: were this ground goes ?? (b33r-ninj4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b33r-ninj4 &raquo;</TD></TR><TR><TD CLASS="quote">there is a bolt that it mounts to on the valve cover. i dont see it the pic though</TD></TR></TABLE>
should be somewhere close to the bottom right corner
Old Feb 22, 2006 | 03:54 PM
redeg61987's Avatar
thanks for the fast responses im going to go check it out
Old Feb 22, 2006 | 03:55 PM
sicones's Avatar
Default Re: were this ground goes ?? (Sh!ttyLS)
that bolted to the power steering but since you dont have it anymore, find a spot on the block to connect it, I think the valve cover would be a bad spot because its totataly rubber gasketed from the rest of the engine
Fuster_Cluck's Avatar
Something like this:
Picture by Brewer:
Old Feb 22, 2006 | 04:01 PM
fmrprojects's Avatar
Default Re: were this ground goes ?? (Hybrid93Hatch)
put it on the valve cover bolt that holds down the valve cover. its a better ground
Old Feb 22, 2006 | 04:06 PM
redeg61987's Avatar
Default Re: were this ground goes ?? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">that bolted to the power steering but since you dont have it anymore, find a spot on the block to connect it, I think the valve cover would be a bad spot because its totataly rubber gasketed from the rest of the engine</TD></TR></TABLE>
would it effect any as far as preformance or driving with not grounded to anytihng?
Old Feb 22, 2006 | 04:07 PM
TOASTYYY!!
Default Re: were this ground goes ?? (fmrprojects)
In the pic that is posted above its in the wrong spot on the valve cover. it actually goes in the hole next to it. Im not sure if it matters though.
Old Feb 22, 2006 | 04:09 PM
TOASTYYY!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redeg61987 &raquo;</TD></TR><TR><TD CLASS="quote">would it effect any as far as preformance or driving with not grounded to anytihng?</TD></TR></TABLE>
You might notice some slight dimming of the lights or the elctrical system but i dont think it will actually affect the performance of it. Dont take my word for it though. I drove around with out that ground for the longest and didnt notice a difference when I hooked it back up.
Old Feb 22, 2006 | 04:15 PM
redeg61987's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">put it on the valve cover bolt that holds down the valve cover. its a better ground</TD></TR></TABLE>+
it doesnt reach my valve cover bolt so cant be hooked to that.
i dont no why it would be for my power steering it seems odd honda would still put it bolted to my car when it never had power steering installed
Old Feb 22, 2006 | 04:21 PM
sicones's Avatar
well that car most likely came with power steering someone must have taken it out, a ground disconnected would cause bad battery charging, weak spark, hard starting etc.. connect it to the block, or AC bracket
Old Feb 22, 2006 | 04:32 PM
redeg61987's Avatar
thanks i haev the orginal window sticker and its not listed but sitll could of been installed i dont i just connect it to the ac bracket
Old Feb 22, 2006 | 05:33 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b33r-ninj4 &raquo;</TD></TR><TR><TD CLASS="quote">In the pic that is posted above its in the wrong spot on the valve cover. it actually goes in the hole next to it. Im not sure if it matters though.</TD></TR></TABLE>
Alot of people strip the bolt that goes in that hole, so they just put the ground on one of the valvecover bolts.
Old Feb 22, 2006 | 06:49 PM
specscow's Avatar
i took mine off it just looked bad the car runs fine with out it
Old Feb 22, 2006 | 10:18 PM
nello a.'s Avatar
that is the one thing i always thought: honda must have had a brain fart-they put a ground on something that has a big gasket(rubber) on it. mine is attached to the valve cover(b16), but i think this ground is worthless.
Old Feb 23, 2006 | 01:50 AM
RangerDan's Avatar
Default Re: (nello a.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">that is the one thing i always thought: honda must have had a brain fart-they put a ground on something that has a big gasket(rubber) on it. mine is attached to the valve cover(b16), but i think this ground is worthless.</TD></TR></TABLE>
Well the bolt doesnt stop at the rubber gasket. It goes into the head so it is a good ground point.
To the original poster that wire shouldnt have any trouble reaching the valve cover bolt in the pic, put it there and be done with it. While your there you should take off that valve cover strip and repaint....do it some justice.
Old Feb 23, 2006 | 03:06 AM
eg4metodrive's Avatar
Default Re: (RangerDan)
Old Feb 23, 2006 | 05:40 AM
redeg61987's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerDan &raquo;</TD></TR><TR><TD CLASS="quote">
To the original poster that wire shouldnt have any trouble reaching the valve cover bolt in the pic, put it there and be done with it. While your there you should take off that valve cover strip and repaint....do it some justice. </TD></TR></TABLE>
thats how i bought the car with the cover already painted
Old Feb 23, 2006 | 06:00 AM
darkcvc's Avatar
Blue Sedan Crew
Default Re: (redeg61987)
This wire can be ground to any part on the head, as long as it is bolted to metal.
It is a common misconception, that thier is a "wrong place" for this.
I dont care if you take 13 ft of wire, wrap it around the motor four times, and then ground it to the back of the head, it will still make a fine ground......
Old Feb 23, 2006 | 06:21 AM
Earthworm Jim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
I hope you get it
Old Feb 23, 2006 | 07:20 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: were this ground goes ?? (The_General)
just ground to the block itself.
Old Feb 23, 2006 | 08:00 AM
Nevaeh Speed's Avatar
here you go
How gay, I jacked up on my spelling.... Dumb ***.
hpi247
Dec 30, 2007 08:15 PM
invisible
25
Nov 24, 2006 11:52 AM
Racermech
Apr 2, 2005 12:31 PM
DSeriesBeeKilla
45
Jul 18, 2003 03:13 AM
cr00klyn718
Sep 30, 2002 02:52 PM
