ITR fuel pump?
Are the fuel pumps diff. from GSR/ITR , ex.
Are the fuel pumps diff. from EG?
I see these articles with people who have bling civics and integras.....they say under mods: ITR fuel pump
I looked in my shop manual, no info on different fuel pumps.
Thanks for help.
Thanks for help.
So, the CX fuel pump in the EG is not for Vtec.....thus. me needing to change fuel pumps.
I see the numbers are different, but is that different years or body styles?
sohc non-vtec,sohc vtec,and dohc non-vtec fuel pumps flow 79lph.
dohc vtec fuel pumps flow 134lph..I have an 89 crx and with the stock fuel pump it was running lean in the upper rev range with the B16a motor..I found this out using a wideband o2,,,Put in a gsr fuel pump and it runs better now..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">sohc non-vtec,sohc vtec,and dohc non-vtec fuel pumps flow 79lph.
dohc vtec fuel pumps flow 134lph..I have an 89 crx and with the stock fuel pump it was running lean in the upper rev range with the B16a motor..I found this out using a wideband o2,,,Put in a gsr fuel pump and it runs better now..</TD></TR></TABLE>
Don't the integra fuel pumps fit differently compared to ef ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
Don't the integra fuel pumps fit differently compared to ef ones?</TD></TR></TABLE>
Yeah they fit alittle different..I kind of rigged it up alittle bit with zip-ties to the bracket and little rubber pieces to get it to sit like the stock fuel pump,,and re-used the stock strainer..And I think they guy with me soldered on diffferent connectors..I forget though,it was a while ago..
So the flow rates are different between Vtec Bseries vs. Single cams<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">sohc non-vtec,sohc vtec,and dohc non-vtec fuel pumps flow 79lph.
EKtypeRhaTcH
May 7, 2005 02:31 AM
Si_Allen
15
Aug 14, 2002 10:42 AM
ef civic
May 26, 2002 10:58 PM
