are cam gears worth $100
Old Feb 22, 2006 | 11:46 AM
big-cat's Avatar
Default are cam gears worth $100
i have a d16y7. with a hks catback system, and a short ram intake. if i buy some cam gears will they help at all???
Old Feb 22, 2006 | 11:50 AM
ek4d00r's Avatar
Default Re: are cam gears worth $100 (big-cat)
not really
Old Feb 22, 2006 | 12:07 PM
Civicse's Avatar
Default Re: are cam gears worth $100 (ek4d00r)
save your money
Old Feb 22, 2006 | 12:23 PM
EJ6_ROY's Avatar
Default Re: are cam gears worth $100 (Civicse)
if you're not doing anything to the head (i.e. cams, etc) then don't bother.
Old Feb 22, 2006 | 12:26 PM
SkoundrelUSA's Avatar
cute little bastard
You only have 1 cam gear , but no you won't really benefit from it with that setup
Old Feb 22, 2006 | 12:35 PM
. a d a m's Avatar
You will barely see any gain from it at all. In your case the only thing it will really do is make adjusting your cam timing a bit easier, something that you shouldn't be playing with anyway unless you know what you're doing.
Bottom line, if you aren't doing anything with the cams or valvetrain, there is almost no reason to have them.
Old Feb 22, 2006 | 12:49 PM
schardbody's Avatar
really depends in my opinion. cam gear/s just shift your powerband in a mostly stock setup.
kpjo4
Jul 11, 2009 06:44 AM
ganjafarmer143
Aug 14, 2005 11:34 AM
JDM00SI
Feb 11, 2005 10:34 AM
Brewer
Feb 2, 2005 10:48 AM
Spaceballsthelunchbox
Dec 13, 2002 09:20 PM
