Alternator Pivot Bolt Specs
Old Feb 22, 2006 | 10:48 AM
fast+forward's Avatar
Default Alternator Pivot Bolt Specs
like title says..what size/thread
Old Feb 22, 2006 | 10:53 AM
mgags7's Avatar
its a 14mm head if i remember right, but its very special dude....sqared, tapered end....just order it from honda
Old Feb 22, 2006 | 11:09 AM
AndyD's Avatar
Default Re: Alternator Pivot Bolt Specs (fast+forward)
I have one available.
Old Feb 22, 2006 | 11:11 AM
slammed95lude's Avatar
I used to be a honda tech, and those bolts have to be from the factory. You might have to buy the whole assembly. Unless you can find one junked. but its a 10mm x 1.25
Old Feb 22, 2006 | 04:50 PM
Default Re: Alternator Pivot Bolt Specs (slammed95lude)
thanks for the info...as for the adjustment hardware under the alternator are they all interchangable between h and f series? i'm talkin about the two 10mm bolts and nuts and the 12mm that goes across the sliding/rail mount.. i'm heading to the local yard, just wanna make sure in case they dont have an h22 to pick off of...
prangy
May 19, 2014 02:57 PM
2ndGenREX
Sep 16, 2007 08:11 PM
wrx'n you
Mar 13, 2006 06:46 PM
rough_draft
Feb 16, 2005 08:29 AM
ShakesTheKlown
Jun 12, 2004 02:24 PM
