tranny fluid change
Old Feb 22, 2006 | 09:35 AM
GarageAlchemist
Guest
Posts: n/a
Default tranny fluid change
I was wondering if anyone knew how to easly change the tranny fluid on a 91 dx hatch, i couldn't find a hole =\
Old Feb 22, 2006 | 09:38 AM
wickedEFguy's Avatar
Default Re: tranny fluid change (GarageAlchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if anyone knew how to easly change the tranny fluid on a 91 dx hatch, i couldn't find a hole =\
go here, Should be self explanatory.
http://www.c-speedracing.com/h...d.php
Old Feb 22, 2006 | 09:58 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: tranny fluid change (wickedEFguy)
yea, i was kinda wanting an easy way to do it, without taking out my entire tranny... lol
Old Feb 22, 2006 | 10:31 AM
ludesrv's Avatar
Remove the 17mm plug half way up the tranny. Remove the 3/8 drive plug from the bottom and watch her drain right out. Keep the car levelled, having it ontop of a pit or on 4 jack stands. Then when she's done draining, run some 10w30 thru it to clean up the bottom. Then put the 3/8 plug back in, tight her down, then fill her up with 10w30 oil (non synthetic) until it starts to poor out of the 17mm bolt hole. Let her level off (remember to keep it leveled!!!) then when she's done draining out, plug her up and you are done.
Takes 15 minutes.
EDIT: All trannies on civic up to 95 (stock D series) use 10w30 oil. Using Honda MTF can cause some damage to the gears. It's up to you to determine what you wanna put in. My 93 prelude takes 10w30 out of factory, I'm running GM Synchromesh fluid, that stuff works wonders on syncros.
Old Feb 22, 2006 | 11:28 AM
Targa250R's Avatar
be professional
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">EDIT: All trannies on civic up to 95 (stock D series) use 10w30 oil. Using Honda MTF can cause some damage to the gears.</TD></TR></TABLE>
Not true at all.
upinsmoke
Nov 19, 2006 09:20 AM
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
Seedc2
Aug 6, 2003 05:59 PM
spencedogg
Jun 1, 2003 06:23 PM
CBR600OnTop
Dec 30, 2002 05:04 AM
