turbo and vtec
Old Feb 22, 2006 | 07:41 AM
lacking vtec's Avatar
Default turbo and vtec
someone explain to me why ppl do ls/vtec swaps and putting turbo on top of it. isn't turbo and vtec basically the same concept? vtec kicks in at a certain rpm, so does turbo. wouldnt the turbo just override that vtec? is it because vtecs tend to have higher redlines?
Old Feb 22, 2006 | 07:47 AM
Tornadom's Avatar
Default Re: turbo and vtec (RagingAlcoholic)
The vtec system is designed to allow variable valve timing. The vtec head flows more efficiently than a non-vtec head, and is better suited to handle the airflow of a turbo motor. Check out this link to see how vtec works...
http://video.google.com/videop...=vtec
Old Feb 22, 2006 | 08:40 AM
chown -R us .base's Avatar
Default Re: turbo and vtec (Tornadom)
Both are performance enhancers. If you are trying to build a faster / quicker car, why not use all available avenues?
They are not the same thing, so there is no cancelling the other out. They both work together.
Old Feb 22, 2006 | 10:10 AM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: turbo and vtec (Stolen94GSR)
definitely not the same thing... Vtec kicks in at a certain RPM level and changes the timing of the valves and camshafts....turbo is a form of forced induction... instead of air being 'sucked in' by an intake or airbox (naturally aspirated or N/A), a turbo spools up your exhaust, cools the air in an intercooler and is forced back into your intake manifold... you need to search/read!
Old Feb 22, 2006 | 10:59 AM
msbhvn_DC2's Avatar
when vtec activates, oil pressure from the seleniods lock up the rockers on ur cams to the biggest lobes. the biggest lobes pushes the valves more than normal allowing more air to pass through the head and into each cylinder. Adding a turbo would just make everything sweeter!
Old Feb 22, 2006 | 11:19 AM
Danza's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAlcoholic &raquo;</TD></TR><TR><TD CLASS="quote">someone explain to me why ppl do ls/vtec swaps and putting turbo on top of it. isn't turbo and vtec basically the same concept? vtec kicks in at a certain rpm, so does turbo. wouldnt the turbo just override that vtec? is it because vtecs tend to have higher redlines?</TD></TR></TABLE>
Two different concepts. Read the posts above and do some research into the theory/purpose behind forced induction and what vtec does.
SIDENOTE: props for being mature guys
Old Feb 22, 2006 | 11:53 AM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: turbo and vtec (Danza)
(--- thinks its lame to flame
hah
Old Feb 22, 2006 | 12:15 PM
integra3586's Avatar
Default Re: turbo and vtec (TiredToyotaDriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiredToyotaDriver &raquo;</TD></TR><TR><TD CLASS="quote">(--- thinks its lame to flame
hah</TD></TR></TABLE>
wow is H-T growing up? this is a first. lots of respect to you guys /\/\/\/\/\/\/\
Old Feb 22, 2006 | 12:25 PM
sydegsr's Avatar
Default Re: turbo and vtec (B18B-SC)
i read in one of my super street magz about the pro am integra, and when he was running all motor with a b18c1, he was running 12's and he couldnt get lower, and now he has a turbo set up, and runs 9's one of the fastest integras in the world.
but there is no replacement for displacement
personally i like the all motor
Old Feb 22, 2006 | 01:07 PM
INTEGRA_boy's Avatar
Default Re: turbo and vtec (sydegsr)
one reason people choose the ls block is because it has a bigger displacement then any other b18 out there..i think by 100cc's more..and if you get a good tune with a b16 head or gs-r head..you will be really fast.
Old Feb 22, 2006 | 01:08 PM
Default Re: turbo and vtec (INTEGRA_boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INTEGRA_boy &raquo;</TD></TR><TR><TD CLASS="quote">one reason people choose the ls block is because it has a bigger displacement then any other b18 out there..i think by 100cc's more..and if you get a good tune with a b16 head or gs-r head..you will be really fast.</TD></TR></TABLE>
its actually 37 more cc's if it were 100 it would be called the b19
b18c=1797 cc
b18b=1834 cc
Old Feb 22, 2006 | 02:18 PM
EX-T's Avatar
I just thought I would post and say that no one flamed this guy! I can't believe it!
Like everyone else is saying, VTEC and Turbocharging are two totally different things but both are great in their own right. You should mix the best of both worlds, B16aT or D16Y8t!!!! HAHAHAHAH
Old Feb 22, 2006 | 02:25 PM
ecks_fourttwo's Avatar
Default Re: turbo and vtec (DSeriesBKilla)
you get the best of both worlds...
WaynePlayer
Oct 26, 2017 06:37 AM
xSOHC
May 24, 2012 06:49 AM
walsh22
Apr 3, 2007 12:42 PM
dayaftertomorrow
May 2, 2005 01:41 PM
Slvr_CRX
Aug 25, 2003 02:56 PM
