OBD 1 B18c into 97 EK, able to use stock civic wiring harness?
Old Feb 22, 2006 | 06:30 AM
2muchPSI's Avatar
Default OBD 1 B18c into 97 EK, able to use stock civic wiring harness?
Well i have a 1995 B18c I'm putting into my 97 Civic EX.
I have a 96 DX wiring harness I'll be using with the motor, with a conversion harness running the stock obd1 p72 ecu. I know I have to wire in Vtec, but am I missing anything else. Should the wiring just be plug and play with the 96 Dx wiring harness and the 95 B18c?
Will the distributor have to be repinned or anything? Any lengthening of wirs?
Thanks for the knowledge
Old Feb 22, 2006 | 09:51 AM
Terrible One's Avatar
Default Re: OBD 1 B18c into 97 EK, able to use stock civic wiring harness? (2muchPSI)
dont forget to wire up the iabs and obd1 injector plugs
Old Feb 22, 2006 | 01:27 PM
2muchPSI's Avatar
Default Re: OBD 1 B18c into 97 EK, able to use stock civic wiring harness? (Terrible One)
If i just run obd 2 civic injectors I shouldn't have to swap out the injector plugs.......I'm having a brain fart here and can't remember what the Iab is?
Old Feb 23, 2006 | 09:10 AM
2muchPSI's Avatar
ahhh Idle air bypass valve, gothca
Old Feb 26, 2006 | 03:56 PM
ReDHaTcHyGuy's Avatar
Default Re: OBD 1 B18c into 97 EK, able to use stock civic wiring harness? (alpha_ek)
what about knock sensor,, you could just buy a ex harness and it all there... and you know that you can't use the dx injector if u plan on using obd2 ones, u need to get ex or Si ones..obd2 teg injectors will work also
Old Feb 27, 2006 | 05:17 AM
2muchPSI's Avatar
Default Re: OBD 1 B18c into 97 EK, able to use stock civic wiring harness? (ReDHaTcHyGuy)
yeah, I totally forgot about the know sensor, hmmmm.
I've got the injectors figured out, but now what do I have to do about the knock sensor since I'll be using a CX wiring harness.
Old Feb 28, 2006 | 03:39 PM
2muchPSI's Avatar
anybody know?
Old Feb 28, 2006 | 04:51 PM
f2m0u5's Avatar
Old Mar 1, 2006 | 05:17 AM
2muchPSI's Avatar
thanks!
RS DC4 94
Feb 7, 2006 11:21 PM
Sinista
Jan 19, 2006 05:00 AM
Myh4tch
Jun 14, 2005 06:56 PM
boostedcivicsir
16
May 9, 2003 09:58 PM
Powered by Honda
Oct 12, 2001 09:30 AM
