Help with my oil light b16 swap
Old Feb 21, 2006 | 07:19 PM
Ak_ef9's Avatar
Default Help with my oil light b16 swap
got the motor from hmo and runs great. The only thing wrong is the oil light comes on only after high rpm. Once it idles it fades back off. I also put a 98 itr cluster. Any comment will help thanks
Old Feb 21, 2006 | 08:04 PM
Ak_ef9's Avatar
Default Re: Help with my oil light b16 swap (Ak_ef9)
no replies after 45?
Old Feb 21, 2006 | 08:08 PM
fourthgenhatchB17's Avatar
Hook up an external gauge and see what the psi really is.
Old Feb 21, 2006 | 08:18 PM
Ak_ef9's Avatar
Default Re: Help with my oil light b16 swap (fourthgenhatchB17)
do I connect it to that single plug on the back of the engine near the oil filter? or that green plug on right under the vtec selinoid?
Old Feb 21, 2006 | 08:23 PM
You have to remove the original sender completely, and im talking about the sender thats by the oil filter. The one by the filter connects to your light on the cluster.
What i would do: go to walmart and buy their $5 universal oil psi gauge. It comes with the correct BSPT adapter so it will thread into the block. Just read the directions that the gauge comes with. If u want a permanent gauge set up, i would step up to something better with stainless line, but the walmart **** does the trick and will let u know if there is a problem quickly. Once the problem is solved, remove everything and reinstall the original 1 wire sender. You might want to search here on HT about "oil psi gauge install" or something like that to get a feel for what u will be doing.
Old Feb 21, 2006 | 10:37 PM
Ak_ef9's Avatar
I dont even have that one plugged inam I suppose to? I thought I hooked up the oil pressure thats under the vtec solenoid.
Old Feb 22, 2006 | 08:10 AM
Ak_ef9's Avatar
help bump
Old Feb 22, 2006 | 04:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">I dont even have that one plugged inam I suppose to? I thought I hooked up the oil pressure thats under the vtec solenoid. </TD></TR></TABLE>
The sender by the filter serves only 1 purpose and thats to operate the light on the gauge cluster. The sender by the vtec solenoid is for the ECU. If the one by the filter isnt even plugged in, then why does your light on the cluster work? I think u said u had a teggy cluster installed....i wonder if u f'd up the wiring.....
Did u wire the cluster in yourself?
Old Feb 22, 2006 | 05:00 PM
Ak_ef9's Avatar
yeah I wiored it my self using
https://honda-tech.com/zerothread?id=458873
and
http://www.angelfire.com/dc/oregonimport/gsr.html
and about 3 other places that helped me through it. I dont think I did it wrong but you never know
Old Feb 22, 2006 | 05:13 PM
Well check on that sender by the filter to see if u have it hooked up. If it is, then follow my tip about the walmart gauge. If its not hooked up, then u messed up somewhere with the wiring. This thread is pretty much done until u put some work in.
Kuhniee
Mar 31, 2011 07:45 AM
cjmitthun
75
Nov 21, 2006 08:35 PM
Average Al
Oct 8, 2004 09:55 PM
94CivSi
May 1, 2003 08:10 PM
gsrroadrunner
May 14, 2002 09:55 PM
