Look what I found in between my cylinder walls and block... RTV???
Old Feb 21, 2006 | 07:00 PM
shatchi's Avatar
Default Look what I found in between my cylinder walls and block... RTV???
Block is a 2.0 sleeved LS. Blew a headgasket and went to take off the head and while I was inspecting the coolant passage ways I saw a few pieces of orange stuff floating around. So I then looked deeper into the passage ways and found that right on the sleeve was chunks of RTV. It was around all the cylinders under the sleeve. Here's some pics of the RTV and where I found it. I know I know, they look like baby aliens but they're really RTV chunks. Any idea of where it could be from or why its there?
And I found all that in here...
Thanks in advance
Old Feb 21, 2006 | 07:04 PM
PLAGUED_DB7's Avatar
Default Re: Look what I found in between my cylinder walls and block... RTV??? (shatchi)
well is sure as hell didnt do you any good on the headgasket cause you still blew it...
Who built that ****?
Old Feb 21, 2006 | 07:41 PM
TypRice's Avatar
ditto....who built ur motor?
fire them!
Old Feb 21, 2006 | 08:04 PM
ITR#132's Avatar
Who did the sleeve job? Could be the adhesive used when re-sleeving.
MR. BAR's Avatar
GE sleeved. I dont know the builder, guess thats what i get for buying a used block and not asking enough questions. Any ideas? Bump for my pooor block.
Old Feb 21, 2006 | 08:17 PM
MR. BAR's Avatar
We didnt use RTV on the head gasket, we didnt know that stuff was in there untill after we ran the motor for about a week.
Old Feb 21, 2006 | 08:45 PM
MR. BAR's Avatar
Default Re: (BayAreaRacing)
Someone suggested that it could have been used as a valve cover sealer and when they peeled it off the excess stuck to the block and dried, where it later broke loose and fell into the coolant passages?
Old Feb 21, 2006 | 10:23 PM
deanh8's Avatar
call the guy you got the motor from and find out who did the motor.
Are you sure you blew a head gasket? Didn't you say it looked fine?
It could have been something else, maybe the RTV was sealing something and it got too hot and came off causing whatever it was sealing to be exposed and coolant to get into your motor.
Modified by deanh8 at 3:06 AM 2/22/2006
Old Feb 22, 2006 | 05:07 AM
gsp ej1-em1's Avatar
faulty.
Old Feb 22, 2006 | 05:39 AM
K-Drum's Avatar
ever use any stop leak stuff in your colling system ? this could be resudu from it. basicaly is hardens when the coolant is cold but once it's warmed up it turns to liquid form plugging any leaks you would have in your cooling system... if not you possibly the folks you bought the block from there were some residu in the block itself.
quick test, take a peice of it and place it in boiling water if it melts it's not a huge consern... if not... not a clue.
Old Feb 22, 2006 | 05:57 AM
X-Mazda 3 Racer's Avatar
Default Re: (K-Drum)
That is our old block sleeving process. Check your IM
Old Feb 22, 2006 | 09:24 AM
MR. BAR's Avatar
If it was from a sleeve, would that mean it dropped a sleeve? Because we measured and all the sleeves look level.
If i put it in boiling water and it melts what would my huge problem be? A crack somewhere in the coolant passages of the block?
Thanks Vine for the quick reply, i will get you that serial number tonight.
Old Feb 22, 2006 | 09:27 AM
Tizight's Avatar
He said if you put it in boiling water and it melts it wouldnt be a huge problem.
Old Feb 22, 2006 | 09:36 AM
MR. BAR's Avatar
Ohh thanks for the correction Tizight.
Dean, guy i bought it from contacted the guy he bought it from bought it from, he was unable to contact or get any info on the guy he bought it from. Looks like the block has come a long way, and no one can find the original owner.
Old Feb 22, 2006 | 12:44 PM
scheistermeister's Avatar
or no one wants to fess up to their mistakes
Old Feb 22, 2006 | 12:55 PM
INTEGRA_boy's Avatar
Default Re: (scheistermeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scheistermeister &raquo;</TD></TR><TR><TD CLASS="quote">or no one wants to fess up to their mistakes</TD></TR></TABLE>
that has to be what it is..lawsuits baby.. for the broken motor
Old Feb 22, 2006 | 01:57 PM
MR. BAR's Avatar
Not sure its a broken motor yet guys. I posted this in two sections, had multiple responses that they found the same thing in their motors shortly after sleeving. I think im going to try it again, now that the coolant system is flushed and i have a new head gasket. See what the results are, if it happens again then we have some serious issues, whether it be warped head or bad sleeves. If not, then happy boosting. Prey for me guys.
Old Feb 22, 2006 | 09:26 PM
buckNasty's Avatar
actually no
as im the seller
and ive been there for eric the entire time
even though this was sold to him like 6 months ago
and even done in a split payment fashion
so before you guys with almost no time or experience on here decide to run your mouths, please be sure to know the whole story before you speak.
and eric knows this as this is why hes not badmouthing me or bringing in my name in a negative fashion. ive been doing everything i can to help him even though it was an "as is" sale.
Old Feb 22, 2006 | 09:54 PM
iheartDc2's Avatar
woo
Old Feb 23, 2006 | 11:16 AM
Finger Lickin' good's Avatar
Default Re: Look what I found in between my cylinder walls and block... RTV??? (iheartDc2)
my theory esh, high temp rtv is suppose to be good. a 2.0 sleeved motor is a serious monster, expect it to need maintainence. Head gaskets blow, it lasted 6 months, sounds about right. This is why daily drivers cant be monsters. This is why Ive got my internally bone stock ls. Lessons learned the hard way are the best way.
Old Feb 27, 2006 | 05:05 PM
DynastyRacer22's Avatar
look like shrimps
Old Feb 27, 2006 | 11:47 PM
MR. BAR's Avatar
Default Re: Look what I found in between my cylinder walls and block... RTV??? (Finger Lickin' good)
The car was not driven for 6 months, only about a week and less than 100miles, and non boosted.
Old Feb 28, 2006 | 05:43 AM
Sam92Teg's Avatar
Default Re: Look what I found in between my cylinder walls and block... RTV??? (BayAreaRacing)
Looks to me like a noob builder thought that the block guard shouldn't allow any fluid to the top of your cylinders and tried to seal it with RTV. Make sure to have the passages cleaned out, maybe a good soak in one of those block cleaners at a machine shop.
2LiterTurboSeR
Jan 9, 2010 02:29 PM
E85B18
Oct 15, 2009 09:05 AM
shatchi
Mar 16, 2006 06:20 PM
FOrSfEd
Mar 23, 2004 05:54 PM
92BlackSi
Aug 31, 2003 08:41 AM
