I recommend everyone do this
Old Mar 28, 2002 | 09:30 AM
94CivicSi's Avatar
Default I recommend everyone do this
thanks again for all the informative posts about the famed broken lower rear shock bolt. For those that missed it, I broke one over the weekend. The bolts were seized inside the bushing in the LCA. If you don't own a hydraulic press (no one does), this is not a job you can do on your own. Take it from a fool and his recently parted wad of cash. In an effort to save everyone else this headache and expense, do this:
If you've got an extra 10 minutes this weekend, jack up the rear of your car and remove these 2 bolts. BATHE them in anti-seize, get it at any parts store. Reinstall.
That's all there is to preventing the same thing happening to you. Trust me on this one.
Old Mar 28, 2002 | 09:40 AM
Schmedley's Avatar
New User
Default Re: I recommend everyone do this (94CivicSi)
Thats funny, because mine broke about 2 months ago and i had to rig it to work. I guess I did a pretty good job since it hasnt giving me any problems. Wish I learned this before hand though.
[Modified by Schmedley, 1:41 PM 3/28/2002]
Old Mar 28, 2002 | 09:46 AM
3.3.3's Avatar
Default Re: I recommend everyone do this (Schmedley)
amen. i did that to my rear bolts replacing the shocks to GAB's....i totally stripped those mothers. ended removing the shole arm just to get those SOB's off.
Old Mar 28, 2002 | 12:59 PM
Russ713's Avatar
dAng!
i've never had a problem removing or re-installing them.
Old Mar 28, 2002 | 01:17 PM
MaxBoost's Avatar
New User
Default Re: I recommend everyone do this (Black Light)
Mine seized inside the bushing too on my 95 hatchback. I bought a complete LCA for $30 and a new bolt..problem solved.
Old Mar 28, 2002 | 01:34 PM
BROOD's Avatar
If I only had a dollar for every lca bolt that siezed up on me...I'd be rich. Too common of a problem living in a state like IL (salt, snow, salt, rain, salt, salt).
Definitly pack those up with anti-sieze.
Old Mar 30, 2002 | 12:15 PM
filipinium's Avatar
that happened to me too. i ended up cutting off the old shock with a grinder. then i took a rotary (rotozip) to hollow out the bushing, thus removing the siezed bolt. after this was done, only the metal sleeve of the bushing was left in the control arm. to take it out, i took a hack saw and sawed out the metal sleeve (being careful not to damage the control arm. then i bought some new bushings from honda and installed them. the first one took a while to do, but the second time went a lot quicker.
it's a pain in the ***, but well worth the money i saved instead of having a shop do it.
cehcivic15
14
Jun 18, 2012 12:50 PM
usmarinedelta
Dec 27, 2006 08:52 PM
Del Sol Man
72
Jun 21, 2006 08:13 AM
Soda Popinski
Mar 30, 2004 05:18 PM
Integra_Nguyen
Aug 10, 2002 06:58 PM
