Car SHAKES when i start moving like its going to stall. HELP
Old Feb 21, 2006 | 06:18 PM
mikeunreal2's Avatar
Default Car SHAKES when i start moving like its going to stall. HELP
Whenever i start moving in first my car SHAKES. Its like its not gettin enough gas. I am currently running with my TPS unplugged due to surging idlling, so its not running right. Would this have anything to do with shaking in first once i start moving? Also, it seems like ever since i put on my apexi ws2, its shaken alot worse. I think its hitting my shift linkage and viabrating it. I have some ghetto short shift kit on my car, thinking of just taking it off.
Mike
Old Feb 21, 2006 | 06:21 PM
Default Re: Car SHAKES when i start moving like its going to stall. HELP (mikeunreal2)
oh btw my car idles at about 1500-2000. Would the fact that its idleing so high have something to do with it?
Mike
Old Feb 21, 2006 | 06:22 PM
JDMKid71's Avatar
yeah unpluging your TPS has everything todo with your engine not running right... 10:1 your running WAY to lean for one. plus without the TPS your ECU cant use anything but the map sensor to derermin the amount of fuel to give it. you need to plug your TPS back in and just deal with the idle problem. my cars doing it also... have you checked the FITV? and/or the EACV (i think honda calls them the IACV). your TPS is NOT the only thing that will make your idle surge... with key on engine off hook a volt meter upto your TPS and measuer the voltage.. there should be ~.5vs when throtle is closed. and ~4.5v then at WOT. but most deff plug your TPS back in
Old Feb 21, 2006 | 07:51 PM
Default Re: Car SHAKES when i start moving like its going to stall. HELP (JDMKid71)
it doesnt surge with it unplugged tho. I replaced my iacv, no use. Ive tried to check my fitv, but havnt had a chance. Id rather it run like **** and get shitty gas milage for now then have it idle like it is. I might just have to bring it to a shop and get them to find out why its surging. Its driving me CRAZY
Mike
Old Feb 24, 2006 | 04:22 PM
JDMKid71's Avatar
it should be your FITV check that before you take it to a shop... just with you engine warmed up take off your intake tube and put your finger on the bottom hole in the TB. if there is suction with the car fully warm thats your propblem. the valve is bad.
Old Feb 24, 2006 | 05:25 PM
do i need to replace the whole thing or can i fix the fitv somehow?
B_Swapped93
Apr 23, 2014 12:36 PM
THA DOHCTOR
Engine Management and Tuning
Jun 17, 2012 04:06 PM
1baddcivicsi
Sep 19, 2009 08:09 AM
kaj
Feb 20, 2006 04:38 PM
scrEaMO Kyle
Oct 24, 2005 10:42 PM
