Idle problem only under load...
Old Feb 21, 2006 | 04:25 PM
jdkornlp's Avatar
Default Idle problem only under load...
I have a 99 Civic Si with a b16 in it running a p28 with crome. The car has been tuned and i am still currently unable to figure out the idle issue. At idle with all loads off, the rpm's stay exactly where they are supposed to be. If i turn on ANY load, it will start to fluctuate about 500rpm back and forth until i turn the load off. This is a problem because its so bad that if i don't slowly drop the rpm's back down while coming to a stop, the rpm will drop too low and the car will shut off. Also, there are no codes showing up.
Things i've done:
Replaced Alternator
Reconnected/Cleaned all grounds
Replaced IAC valve
Replaced Plugs, wires, cap, rotor
Thanks in advance for any help/suggestions.
Old Feb 22, 2006 | 02:11 AM
jdkornlp's Avatar
Default Re: Idle problem only under load... (jdkornlp)
bump for help
Old Feb 23, 2006 | 02:32 PM
jdkornlp's Avatar
anyone???
hell0curry
Apr 4, 2012 11:20 PM
andysila
Apr 4, 2006 06:46 AM
jdkornlp
Sep 6, 2005 05:12 PM
jaycapz
Sep 1, 2004 02:43 PM
d4rks1d3
Jun 3, 2004 09:21 AM
