Help #4 in dead
Old Feb 21, 2006 | 01:48 PM
2kTeg's Avatar
Default Help #4 in dead
So i've been trouble shooting my car since i put this new motor in.. The motor came out of a friends stock crx and ran fine when it was removed.
I got everything else worked and have no codes
it idles rough like its running on 3 cylinders
so i pulled the plug wires while it was running and #4 is the only one that makes no difference if its conected or not
what could this be... i really don't think the motor is dead it was fine when we removed it
thanks
Old Feb 21, 2006 | 02:29 PM
wob's Avatar
wob
Default Re: Help #4 in dead (2kTeg)
Try another plug wire... Or a new plug... Maybe the injector is clogged ... If its none of them check compression
Old Feb 22, 2006 | 05:15 PM
2kTeg's Avatar
Default Re: Help #4 in dead (wob)
checked spark via grounded the strap and the cars got spark in #4
fuel injector was switched with a good one and still no love from #4
next i will do compression, but i have to buy a tool for that, so if anyone has any other suggestions that would be great
this motor just didn't all a sudden die. It ran good in a stock rex, was pulled, put in mine and now #4 doesn't make a difference when i pull the plug car runs the same regardless if its attached or not
Old Feb 22, 2006 | 05:20 PM
ludesrv's Avatar
Check the cap and rotor. Might have a messed up rotor.
Actualy I bet the cap was damage in the swap.
deraj1986
May 30, 2010 01:28 PM
Duster
Nov 28, 2005 06:17 PM
Origin
Oct 6, 2004 07:37 PM
TruePlayaz114
Mar 21, 2003 12:53 PM
Projekt20
Oct 11, 2002 10:24 PM
