just put in a new itr climate control and heat wont come on?
i had an ls climate control and switched it out and put in the itr one and put everything back how i saw it before and now my heat dont work can someone help me out ? also i put the heater wire back where it goes and it wont work like if i put it to cold its fine then once i put it to heat it doesnt wanna stay there it like wants to come in the middle or go towards cold what am i doin wrong?
right where you hook on the temp cable under the passenger side dash, there's a hook/clamp that holds that cable in place...make sure the cable is clamped into place, if so, then unclamp it and clamp it back on further up the cable or vise versa...kinda hard to explain.
ok, what you did was BEND the metal cable. you need to pop the climate control back out, and "re-bend" the metal cable back into shape. Meaning "straight".
then carefully route the cable back where it should be. connect the plugs, screw everything in.
Then plug the cable back onto the heater bracket thing. Do this part last. push the ac control all the way to cold. pull the heater bracket all the way in and then connect it together.
yo so the metal cable anit suppose to be bended?
so that part that is bended i need to bend it back straight and then connect it back to the bracket and then put all the plugs in then push the ac control all the way to cold? and what u mean pull the heater bracket all the way in
that dont make sense though cuz i just looked at it and if i bend the metal part straight then how is it suppose to hook into the bracket and the bracket is down? u kno what im sayin not sayin u wrong just that if i bend the wire straight what is it gonna grab onto ?
yes, the loop is there for a reason... dont bend that.
if nothing else is bent, then ur prolly just hooking up the end part of it wrong.
push the heater bracket all the way to the right, then hook it up. see if that works.
