spoon drain plugs are great, sohc trannys are poo poo.
I took off the old tranny last night and took out the drain plug, it looked like a tiny metallic troll, i wish I had taken a picture because words cannot do it justice. I suggest buying these plugs if anyone has not yet.
What is the big difference between the DOHC and SOHC trannies?
I would like to get an LSD but I cannot swap it out and put it in a DOHC later on.
my oem one looks like a christmas tree ..
there are so many metal chips and flakes ...
i thought the oem one is magnetic ...
D series trannys, $20 each for synchros
B series trannys, cheaper to buy another tranny reather than replace the synchros.
Got a 3rd gear grind?
did you change the aluminum o ring and torque it down correctly? That o ring must be changed every time, its a crush gasket.
OMG, another from the 'Nati.
never changed the alum. washer, never needed too.
BTW why a SPOON magnetic drain plug for a tranny? Isn't the factory double magnet setup enough?
YES IT IS!
Fastest SOHC in town.
YES IT IS!
A D NOH
Jul 22, 2003 10:54 AM
